HP Pavilion 14-cf0014dx Fan Replacement
    1. HP Pavilion 14-cf0014dx Fan Replacement, Back Panel: step 1, image 1 of 1
      • Flip the device over so that the backside is facing you.
      • Remove the rubber feet to expose six screws.
      • Using the Phillips #1 screwdriver, remove six screws securing the back panel to the device.
      Ask FixBot
    2. HP Pavilion 14-cf0014dx Fan Replacement: step 2, image 1 of 1
      • Insert a plastic opening tool and run it along the edges of the laptop.
      • Remove the back panel from the device.
      Ask FixBot
    1. HP Pavilion 14-cf0014dx Fan Replacement, Battery: step 3, image 1 of 1
      • Using the Phillips #0 screwdriver, remove the four screws securing the battery in place.
      Ask FixBot
    2. HP Pavilion 14-cf0014dx Fan Replacement: step 4, image 1 of 1
      • Lift the battery up and out and remove it from the device.
      Ask FixBot
    1. HP Pavilion 14-cf0014dx Fan Replacement, Fan: step 5, image 1 of 1
      • Using the Phillips #0 screwdriver, remove the two screws securing the fan to the motherboard.
      Ask FixBot
    2. HP Pavilion 14-cf0014dx Fan Replacement: step 6, image 1 of 2 HP Pavilion 14-cf0014dx Fan Replacement: step 6, image 2 of 2
      • Carefully lift the fan up and out of the device.
      Ask FixBot
    3. HP Pavilion 14-cf0014dx Fan Replacement: step 7, image 1 of 1
      • Disconnect the fan from the motherboard and fully remove the fan from the device.
      Ask FixBot
Sam Cole
813 Reputation
7 Guides authored
UMass Dartmouth, Team 2-7, Sinclaire Fall 2021 Member of UMass Dartmouth, Team 2-7, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G7
3 Members
84 Guides authored
1 Guide Comment
Why remove the battery?
Chrillusionist - Reply Share
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 20
All Time: 705
