HP Pavilion 14-bk061st RAM Card Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
63
All Time:
862
Comments: 1
1 comment on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 4 - 6 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Random Access Memory, or RAM for short, is computer memory that is used by an application or program when it is running on a computer. If you have a RAM card with a small size of memory installed in your HP Pavilion 14-bk061st, applications may run slowly and it will be difficult to have many applications open at the same time. Tasks such as gaming or 3D modeling will be next to impossible without the computer severely slowing down.
This device comes with 8 GB of RAM with additional space for another RAM card if you choose to upgrade.
When you are working with or around any electrical components it is recommended that you take care to ground yourself so that you do not electrically shock any components and ruin them. You can ground yourself using an anti-static wrist strap.
Tools
    1. HP Pavilion 14-bk061st RAM Card Replacement, Back Panel: step 1, image 1 of 2 HP Pavilion 14-bk061st RAM Card Replacement, Back Panel: step 1, image 2 of 2
      • Remove the three 5.7 JIS #1 screws from the bottom of the laptop.
      • Remove the two 6.7mm JIS #1 screws from underneath the feet of the laptop close to the exhaust vent.
      Ask FixBot
    2. HP Pavilion 14-bk061st RAM Card Replacement: step 2, image 1 of 1
      • Unclip the back plate using a plastic opening tool.
      Ask FixBot
    3. HP Pavilion 14-bk061st RAM Card Replacement: step 3, image 1 of 1
      • Carefully remove the back plate from the laptop.
      Ask FixBot
    1. HP Pavilion 14-bk061st RAM Card Replacement, RAM Card: step 4, image 1 of 1
      Tool used on this step:
      Halberd Spudger
      $2.99
      Buy
      • Use the hook end of the Halberd spudger to pull back the clamps holding the card in place.
      • Take care when pulling the second clamp as the card has a tendency to jump out.
      Ask FixBot
    2. HP Pavilion 14-bk061st RAM Card Replacement: step 5, image 1 of 1
      • Remove the card by pulling it up and away from the slot.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Make sure that that the card is fully inserted otherwise your computer may not work and the card may be damaged. If the card is not seated properly it may come out of its slot and hit other components inside the laptop when it is moved around.
3 other people completed this guide.
Sayyed Raza
154 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 63
All Time: 862
