Introduction
This is a step-by-step guide on how to remove and replace a wireless card in your HP Pavilion 14-b120dx laptop. Whether you are experiencing hardware failure, difficulty connecting to the internet, or just need to upgrade to a better card, this simple guide will help you quickly and safely replace and install a new Wi-Fi card to your device.
Before you begin this project, we recommend that you find a clean, dry, and flat surface to work on. Power off your laptop completely and unplug it from the charging adaptor and any peripherals.
Insert the plastic opening tool between the keyboard and the palm rest.
Pry upwards until the keyboard section detaches from the laptop.
Repeat this around the edge of the entire keyboard.
Unscrew the 10 6.0 mm screws under the keyboard housing with a Philips #0 head screwdriver.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
