HP Pavilion 14-b120dx Keyboard Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
4
Past 7 Days:
26
Past 30 Days:
106
All Time:
1,570
Comments: 3
3 comments on steps.
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If your HP Pavilion 14-b120dx laptop has sticky keys, missing components, or an overall malfunctioning keyboard, it might be time to replace the keyboard. This operation isn’t as hard as one may think. In fact, with the right materials, you can tackle this job in just a few steps. For precise instructions, use this guide to replace the keyboard.
Before starting, make sure your device is turned off and disconnected from any power sources. Transfer your laptop to a stable, dry, working surface to begin the operation.
The installation process is just the reverse order of the removal process.
Tools
    1. HP Pavilion 14-b120dx Keyboard Replacement, Battery: step 1, image 1 of 1
      • Power down the laptop and detach the charging cord (failure to do so can result in electrical shock).
      Ask FixBot
    2. HP Pavilion 14-b120dx Keyboard Replacement: step 2, image 1 of 3 HP Pavilion 14-b120dx Keyboard Replacement: step 2, image 2 of 3 HP Pavilion 14-b120dx Keyboard Replacement: step 2, image 3 of 3
      • Flip the laptop upside down so that the bottom is facing you.
      • Push the slide on the right toward the center of the laptop, releasing the battery latch.
      • Lift the battery up and away from the laptop.
      Ask FixBot
    1. HP Pavilion 14-b120dx Keyboard Replacement, Keyboard: step 3, image 1 of 3 HP Pavilion 14-b120dx Keyboard Replacement, Keyboard: step 3, image 2 of 3 HP Pavilion 14-b120dx Keyboard Replacement, Keyboard: step 3, image 3 of 3
      • Insert the plastic opening tool between the keyboard and the palm rest.
      • Pry upwards until the keyboard section detaches from the laptop.
      • Repeat this around the edge of the entire keyboard.
      • Sections will make loud snapping noises as they detach from the palm rest - this is normal.
      Ask FixBot
    2. HP Pavilion 14-b120dx Keyboard Replacement: step 4, image 1 of 2 HP Pavilion 14-b120dx Keyboard Replacement: step 4, image 2 of 2
      • Lift the keyboard slowly up until the connecting cable is exposed.
      • Carefully lift the flap on the ZIF connector using a fingernail or plastic opening tool. This will release the cable.
      • Detach the cable.
      Ask FixBot
Joshua Carberry
240 Reputation
2 Guides authored
UMass Dartmouth, Team 4-4, Catania Fall 2016 Member of UMass Dartmouth, Team 4-4, Catania Fall 2016
UMASSD-CATANIA-F16S4G4
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 26
Past 30 Days: 106
All Time: 1,570
