HP Pavilion 14 hard drive
  1. HP Pavilion 14 hard drive, Keyboard & Touchpad Panel: step 1, image 1 of 2 HP Pavilion 14 hard drive, Keyboard & Touchpad Panel: step 1, image 2 of 2
    • Turn the laptop over.
    • Remove all nine 3mm screws on back panel with a Phillips Head 1 driver.
    Ask FixBot
  2. HP Pavilion 14 hard drive: step 2, image 1 of 3 HP Pavilion 14 hard drive: step 2, image 2 of 3 HP Pavilion 14 hard drive: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • Pry off the four rubber bumpers, located at the top corners and center of the back panel, off with a pair of tweezers.
    • Bumpers are delicate and can be easily ripped.
    • Unscrew the four 3mm screws under the bumpers using a Phillips Head 1 screwdriver.
    Ask FixBot
  3. HP Pavilion 14 hard drive: step 3, image 1 of 2 HP Pavilion 14 hard drive: step 3, image 2 of 2
    • Flip the laptop right side up and open the clamshell.
    • Starting at the bottom right corner, slide the opening tool into the crevice between the blue and silver panels.
    • Carefully pry the top casing up around the edges, moving counterclockwise.
    • Keep the tool steady throughout, as prying in a rough manner can break the casing.
    • You will hear audible clicking sounds as the clips connecting the two halves disconnect from each other.
    Ask FixBot
  4. HP Pavilion 14 hard drive: step 4, image 1 of 1
    • Close the laptop and orient it on its side (clamshell hinge up), carefully holding it steady to ensure its safety.
    • Insert the opening tool inside of the hinge and pry with an even amount of force to disconnect the keyboard panel from the fan grate.
    Ask FixBot
  5. HP Pavilion 14 hard drive: step 5, image 1 of 3 HP Pavilion 14 hard drive: step 5, image 2 of 3 HP Pavilion 14 hard drive: step 5, image 3 of 3
    • Reorient the laptop in an upright fashion and open the clamshell.
    • If needed, continue to pry the silver keyboard panel from the rest of the hardware with minimal force.
    • Slowly slide the silver keyboard panel towards you while lifting gently to separate the halves.
    • The panel is still connected by a series of delicate connectors glued to the mainframe, so do not pull the panel right off.
    Ask FixBot
  6. HP Pavilion 14 hard drive: step 6, image 1 of 3 HP Pavilion 14 hard drive: step 6, image 2 of 3 HP Pavilion 14 hard drive: step 6, image 3 of 3
    • While keeping silver keyboard panel hovering above the laptop, locate the touchpad connector ribbon attached to both the silver panel and motherboard.
    • With your finger, flip up the white clasp that holds the connector, releasing the connector ribbon.
    • Unpeel the connector ribbon from its position on the motherboard.
    Ask FixBot
  7. HP Pavilion 14 hard drive: step 7, image 1 of 3 HP Pavilion 14 hard drive: step 7, image 2 of 3 HP Pavilion 14 hard drive: step 7, image 3 of 3
    • With your finger, flip up the white clasp that connects the larger keyboard connector to the motherboard, releasing the connector ribbon.
    • Gently pull the connector ribbon from the clasp.
    Ask FixBot
  8. HP Pavilion 14 hard drive: step 8, image 1 of 1
    • Lift the keyboard panel up and away from the CPU, completely revealing the mainframe.
    Ask FixBot
  9. HP Pavilion 14 hard drive, Battery and Speakers: step 9, image 1 of 1
    • With the internal hardware exposed, disconnect the battery cable from the motherboard.
    • If tightly fastened, gently wiggle the plug out of the jack.
    Ask FixBot
  10. HP Pavilion 14 hard drive: step 10, image 1 of 1
    • Remove the three 4mm screws around the perimeter of the battery pack with a Phillips Head 1 screwdriver.
    Ask FixBot
  11. HP Pavilion 14 hard drive: step 11, image 1 of 3 HP Pavilion 14 hard drive: step 11, image 2 of 3 HP Pavilion 14 hard drive: step 11, image 3 of 3
    • Flip up the two white clasps that hold the connector ribbon to the battery to release the ribbon.
    • Remove the 'motherboard to USB board' connector ribbon from its place.
    Ask FixBot
  12. HP Pavilion 14 hard drive: step 12, image 1 of 1
    • Detach the speaker cable from its fastener on the motherboard by pulling it out with your fingers or using a spudger.
    Ask FixBot
  13. HP Pavilion 14 hard drive: step 13, image 1 of 3 HP Pavilion 14 hard drive: step 13, image 2 of 3 HP Pavilion 14 hard drive: step 13, image 3 of 3
    • Using your fingers, gently pry out the two L-shaped speaker panels from between the external casing and battery pack.
    • Be sure to apply an evenly distributed upwards force on the speaker when lifting it out
    • Both speaker components (located adjacent to each other) will remain connected by a red cable after removal
    Ask FixBot
  14. HP Pavilion 14 hard drive: step 14, image 1 of 1
    • Lift out battery pack.
    Ask FixBot
  15. HP Pavilion 14 hard drive, Motherboard: step 15, image 1 of 2 HP Pavilion 14 hard drive, Motherboard: step 15, image 2 of 2
    • Remove the two Wi-Fi antenna cables that are attached to the Wi-Fi card by pulling them up.
    Ask FixBot
  16. HP Pavilion 14 hard drive: step 16, image 1 of 1
    • Using your fingers, pull the cooling fan cable from its fastener on the motherboard
    Ask FixBot
  17. HP Pavilion 14 hard drive: step 17, image 1 of 1
    • Remove the 3mm screw that holds down the Wifi mini-PCI card using a Phillips Head 1 driver.
    Ask FixBot
  18. HP Pavilion 14 hard drive: step 18, image 1 of 1
    • Remove the three 3mm screws that hold the cooling fan in place using a Phillips Head 1 driver.
    Ask FixBot
  19. HP Pavilion 14 hard drive: step 19, image 1 of 1
    • In the upper right hand corner of the device, remove the 6mm screw holding the PCB board in place by using a Phillips Head 1.
    Ask FixBot
  20. HP Pavilion 14 hard drive: step 20, image 1 of 3 HP Pavilion 14 hard drive: step 20, image 2 of 3 HP Pavilion 14 hard drive: step 20, image 3 of 3
    • Remove the three 3mm screws from the surface of the motherboard using a Phillips Head 1.
    Ask FixBot
  21. HP Pavilion 14 hard drive: step 21, image 1 of 2 HP Pavilion 14 hard drive: step 21, image 2 of 2
    • Carefully lift the motherboard up towards the screen as if it was hinged on one side.
    • To prevent possible scratching, cover the screen with a cloth.
    Ask FixBot
  22. HP Pavilion 14 hard drive, HP Pavilion 14 hard drive: step 22, image 1 of 1
    • Remove the 3mm screw located directly above the NGFF SSD card using a Phillips Head 1 driver.
    Ask FixBot
  23. HP Pavilion 14 hard drive: step 23, image 1 of 2 HP Pavilion 14 hard drive: step 23, image 2 of 2
    Buy
    • Pull the SSD card up and out using your fingers.
    • Do not use tweezers or any other metal tool to extract the card, as it is fragile.
    Ask FixBot
2 other people completed this guide.
Danica Dunville
349 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 98
All Time: 7,122
