HP Pavilion 14 Notebook Battery Replacement
    1. HP Pavilion 14 Notebook Battery Replacement, Remove Enclosure: step 1, image 1 of 1
      • Unscrew the 5 P1 Philips screws (2 under the rubbers). You can esaily follow: HP official video to Remove the Base Enclosure
      • Once you pull up the sides of the cover (e.g. with a pick). You will feel it is still attached in the middle. You can squeeze your hand under the enclosure and push from the middle to liberate a clip in the middle of the enclosure. Pulling directly from the sides feels like the cover will break.
      • If you are not sure of the model of the computer/battery. you can do this step to check the battery model before buying it and then close it again doing the inverse.
      Ask FixBot
    2. HP Pavilion 14 Notebook Battery Replacement, Replace Battery: step 2, image 1 of 2 HP Pavilion 14 Notebook Battery Replacement, Replace Battery: step 2, image 2 of 2
      • You can check the battery model (top-left of the battery), for our case HT03XL, with this reference you will be able to get the propper replacement.
      • If you have the replacement you can unscrew the 5 P1 Philips screws. The top part will have the connector you will need to disconnect to remove the battery. You can follow HP official video to remove the battery
      • Connect the new battery and screw again the 5 screws.
      Ask FixBot
To reassemble the enclosure, clip it again and screw again the 5 screws (follow Step 1 instructions in reverse order).
Oriol CN
125 Reputation
1 Guide authored
1 Guide Comment
Nice explanation about the disassemble the hp notebook laptop. And replace the original battery replacement hp guide
Mahima Singh - Reply Share
Past 24 Hours: 12
Past 7 Days: 67
Past 30 Days: 273
All Time: 7,502
