HP Pavilion 13-s128nr Battery Replacement
    1. HP Pavilion 13-s128nr Battery Replacement, Back Panel: step 1, image 1 of 2 HP Pavilion 13-s128nr Battery Replacement, Back Panel: step 1, image 2 of 2
      • Use the iFixit opening tool to take off the rubber caps.
      • Remove the screws using the Phillips #0 screwdriver.
      Ask FixBot
    2. HP Pavilion 13-s128nr Battery Replacement: step 2, image 1 of 1
      • Use the Jimmy to pry around the seam of the laptop.
      • Remove the back panel of the laptop.
      • Don't completely remove the back panel as there are ribbon cables that can be easily damaged if removed quickly.
      Ask FixBot
    3. HP Pavilion 13-s128nr Battery Replacement: step 3, image 1 of 2 HP Pavilion 13-s128nr Battery Replacement: step 3, image 2 of 2
      • Using the iFixit opening tool to lift the tabs holding in the cables connecting the keyboard to the motherboard.
      • Pull the cable from the motherboard.
      Ask FixBot
    1. HP Pavilion 13-s128nr Battery Replacement, Battery: step 4, image 1 of 2 HP Pavilion 13-s128nr Battery Replacement, Battery: step 4, image 2 of 2
      • Lift upwards on the black tabs the purple strip is connected to.
      • Gently pull the purple strip out of its place.
      Ask FixBot
    2. HP Pavilion 13-s128nr Battery Replacement: step 5, image 1 of 1
      • Using the Phillips #0 screwdriver, remove the five screws holding the battery in place.
      Ask FixBot
    3. HP Pavilion 13-s128nr Battery Replacement: step 6, image 1 of 1
      • Pull the white cable connected to the motherboard out using the iFixit opening tool.
      Ask FixBot
    4. HP Pavilion 13-s128nr Battery Replacement: step 7, image 1 of 1
      • Remove the battery.
      • There are little snap tabs on the right side of the battery. Be sure not to break them by pulling the battery out towards the left side.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 23
All Time: 1,729
