HP Pavilion 11-n010dx Battery Replacement
    1. HP Pavilion 11-n010dx Battery Replacement, Battery: step 1, image 1 of 2 HP Pavilion 11-n010dx Battery Replacement, Battery: step 1, image 2 of 2
      • Use the nylon spudger to remove the rubber pads near the hinge of the screen, then remove the screws under the pads.
      • Use the Phillips #0 to remove four 9mm screws.
      • Use the Phillips #0 to remove seven 6mm screws.
      Ask FixBot
    2. HP Pavilion 11-n010dx Battery Replacement: step 2, image 1 of 3 HP Pavilion 11-n010dx Battery Replacement: step 2, image 2 of 3 HP Pavilion 11-n010dx Battery Replacement: step 2, image 3 of 3
      • Use the nylon spudger to pry the back casing near the hinges for the screen.
      • Continue to pry along the edge of the back case until the back is ready to be removed.
      • Careful when beginning to remove the case. There is a cable attached between the bottom case and the motherboard that must be properly disconnected.
      Ask FixBot
    3. HP Pavilion 11-n010dx Battery Replacement: step 3, image 1 of 2 HP Pavilion 11-n010dx Battery Replacement: step 3, image 2 of 2
      • Use the blue plastic opening tool to lift up on the white tab that is holding the cable in place on the motherboard.
      • Now carefully pull the cable out of place and remove the entire back casing.
      Ask FixBot
    4. HP Pavilion 11-n010dx Battery Replacement: step 4, image 1 of 1
      • Remove the five 6mm screws that hold the battery in place using the Phillips #0.
      Ask FixBot
    5. HP Pavilion 11-n010dx Battery Replacement: step 5, image 1 of 2 HP Pavilion 11-n010dx Battery Replacement: step 5, image 2 of 2
      • Use the nylon spudger to pry away the blue/white wire that is positioned near your battery.
      Ask FixBot
    6. HP Pavilion 11-n010dx Battery Replacement: step 6, image 1 of 2 HP Pavilion 11-n010dx Battery Replacement: step 6, image 2 of 2
      • Disconnect the battery cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
      Ask FixBot
    7. HP Pavilion 11-n010dx Battery Replacement: step 7, image 1 of 1
      • Remove the battery from your device.
      Ask FixBot
3 other people completed this guide.
Joseph Lintz
939 Reputation
5 Guides authored
USF Tampa, Team 11-5, Blackwell Fall 2016 Member of USF Tampa, Team 11-5, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G5
3 Members
60 Guides authored
2 Guide Comments
Only four 6mm screws retaining battery, middle screw secures by passing through back cover. Otherwise very helpful.
norman.huntbach - Reply Share
i followed every step on this guide and when i was finished my laptop wouldn’t turn on
premium destroyers - Reply Share
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 45
All Time: 4,809
