HP PSC 2355 Reflective Document Mat Replacement
    1. HP PSC 2355 Reflective Document Mat Replacement, Scanner Lid: step 1, image 1 of 1
      • Grasp the scanner lid cover from the front of the device and lift lid all the way up until it stands on its own.
      Ask FixBot
    2. HP PSC 2355 Reflective Document Mat Replacement: step 2, image 1 of 1
      • With two hands, grasp the lid on both sides near the hinges and lift straight up to release the lid from each hinge.
      Ask FixBot
    1. HP PSC 2355 Reflective Document Mat Replacement, Reflective Document Mat: step 3, image 1 of 1
      • Once the lid has been removed, lay it on a flat surface with the white mat facing up.
      • Using the flat end of a plastic spudger, pry the mat off at one of the front corners. Do this again for the other front corner.
      Ask FixBot
    2. HP PSC 2355 Reflective Document Mat Replacement: step 4, image 1 of 2 HP PSC 2355 Reflective Document Mat Replacement: step 4, image 2 of 2
      • Once both front corners have been released from the plastic clasps the rest of the mat should easily lift off.
      • Recycle or discard the damaged mat.
      Ask FixBot
Amber Gabaldon
343 Reputation
3 Guides authored
2 Guide Comments
Would a piece of poster board work for a reflective mat?
Karl Dickinson - Reply Share
I don’t think poster board would work because I don’t think it’s reflective enough.
Patricia - Reply Share
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 29
All Time: 1,133
