Up to 20% off select tools
HP PSC 2355 Button Panel Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
85
All Time:
1,592
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
A defective button pad is is not difficult to replace with just a couple tools.
    1. HP PSC 2355 Button Panel Replacement, Scanner Lid: step 1, image 1 of 1
      • Grasp the scanner lid cover from the front of the device and lift lid all the way up until it stands on its own.
      Ask FixBot
    2. HP PSC 2355 Button Panel Replacement: step 2, image 1 of 1
      • With two hands, grasp the lid on both sides near the hinges and lift straight up to release the lid from each hinge.
      Ask FixBot
    1. HP PSC 2355 Button Panel Replacement, Button Panel: step 3, image 1 of 1
      • Once you have removed the scanner lid, locate the finger notch on inside the top left half of the bezel (control) panel.
      Ask FixBot
    2. HP PSC 2355 Button Panel Replacement: step 4, image 1 of 1
      • Place your index finger in the notch and lift up to unsnap the panel.
      • Set panel cover aside.
      Ask FixBot
    3. HP PSC 2355 Button Panel Replacement: step 5, image 1 of 1
      • Use a T9 torx screwdriver to remove the 0.9 cm screw.
      Ask FixBot
    4. HP PSC 2355 Button Panel Replacement: step 6, image 1 of 1
      • From the front of the printer, remove the button panel by pulling it towards you while slightly lifting it up.
      Ask FixBot
    5. HP PSC 2355 Button Panel Replacement: step 7, image 1 of 1
      • Disconnect the white ribbon cable by grasping it between your thumb and index finger.
      • Gently pull to release the ribbon from the green circuit board
      Ask FixBot
    6. HP PSC 2355 Button Panel Replacement: step 8, image 1 of 1
      • Next, use the flat end of a spudger to pry loose the flat ribbon computer cable by the plastic connection end and carefully separate it from the prongs on the button panel.
      • The entire button panel should now be completely disconnected from the printer.
      Ask FixBot
    7. HP PSC 2355 Button Panel Replacement: step 9, image 1 of 1
      • Lay the panel on a flat surface with the backside facing up.
      • Using a T9 torx screwdriver, remove all six 0.7 cm silver screws from the off-white plastic panel.
      Ask FixBot
    8. HP PSC 2355 Button Panel Replacement: step 10, image 1 of 1
      • Gently lift the button panel off the plastic backing with rubber button mat.
      Ask FixBot
    9. HP PSC 2355 Button Panel Replacement: step 11, image 1 of 1
      • Be careful not to lift out and lose the two clear plastic panel separators (these are not fastened to the panel but can easily fall out of the panel if tilted). These are two small plastic parts that sit near the top right and left portions of the panel.
      • Insert your new button panel. To reassemble your printer, follow these instructions in reverse order.
      Ask FixBot
2 other people completed this guide.
Author
with
Patricia
143 Reputation
1 Guide authored
TheFixers Member of TheFixers
Community
2 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 85
All Time: 1,592
