HP Omni 10 Micro Card Reader Board Replacement
    1. HP Omni 10 Micro Card Reader Board Replacement, Battery: step 1, image 1 of 1
      • Remove the back cover from the tablet.
      • The cover is securely fastened to the device and may be difficult to remove.
      Ask FixBot
    2. HP Omni 10 Micro Card Reader Board Replacement: step 2, image 1 of 1
      • Push the black plastic security flaps into an upward position.
      • Lift the small tab on the security strips up and peel them across the battery. They will be attached via adhesive.
      • Lift the tab on the strip up and pull it across the battery.
      • The orange strip does not fully detach from the tablet like the other three. It will only detach from one side.
      Ask FixBot
    3. HP Omni 10 Micro Card Reader Board Replacement: step 3, image 1 of 1
      • Unscrew the ten 3.3 mm screws securing the battery using a 00 Phillip's head screwdriver.
      Ask FixBot
    4. HP Omni 10 Micro Card Reader Board Replacement: step 4, image 1 of 2 HP Omni 10 Micro Card Reader Board Replacement: step 4, image 2 of 2
      • Unhook the cord from the edge of the battery.
      • Pull the wire circuit out and down.
      Ask FixBot
    5. HP Omni 10 Micro Card Reader Board Replacement: step 5, image 1 of 2 HP Omni 10 Micro Card Reader Board Replacement: step 5, image 2 of 2
      • Lift the battery up by its edges and remove it carefully. There will be adhesive holding the battery down.
      Ask FixBot
    1. HP Omni 10 Micro Card Reader Board Replacement, Micro Card Reader: step 6, image 1 of 1
      • Unscrew the two 3.3 mm screws using a 00 Phillip's head screwdriver.
      Ask FixBot
    2. HP Omni 10 Micro Card Reader Board Replacement: step 7, image 1 of 1
      • Lift and remove micro card reader board.
      Ask FixBot
Alex Miller
345 Reputation
5 Guides authored
USF Tampa, Team 1-1, Leahy Fall 2016 Member of USF Tampa, Team 1-1, Leahy Fall 2016
USFT-LEAHY-F16S1G1
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 63
All Time: 849
