HP Omen 15-ax243dx Screen Replacement
Views: 6.5K
View statistics:
Past 24 Hours:
Past 7 Days:
25
Past 30 Days:
143
All Time:
6,472
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 40 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Is your screen cracked or smashed? Will it not turn on? Well you are in luck, if you follow our steps on how to disassembly the screen off the HP-Omen computer and reassembly the screen back on. This guides difficulty is moderate and contains 9 total steps that will take you approximately 20-40 minutes to complete it. This guide will also require the pre-requeste of removing the back cover and the battery. You will need only two tools for this repair guide, a Philips #00 screw-driver and a plastic opening tool.
Tools
    1. HP Omen 15-ax243dx Screen Replacement, Battery: step 1, image 1 of 2 HP Omen 15-ax243dx Screen Replacement, Battery: step 1, image 2 of 2
      • The rear panel is secured by 10 screws. Using a #00 Phillips Screwdriver, remove the ten 1.2 mm screws.
      • The screwdriver should be inserted at the same angle as the screws.
      • Be sure to keep track of the screws and where they came from. Some only fit in to one spot.
      Ask FixBot
    2. HP Omen 15-ax243dx Screen Replacement: step 2, image 1 of 2 HP Omen 15-ax243dx Screen Replacement: step 2, image 2 of 2
      • Insert a plastic opening tool between the rear panel and the top case. Pry the opening tool upwards to separate the top case from the bottom case.
      • Slide the opening tool along the case perimeter to loosen the bottom case.
      • Gently pull the bottom case away from the laptop.
      Ask FixBot
    3. HP Omen 15-ax243dx Screen Replacement: step 3, image 1 of 2 HP Omen 15-ax243dx Screen Replacement: step 3, image 2 of 2
      • Remove the four 1.2 mm Phillips #00 screws around the battery.
      Ask FixBot
    4. HP Omen 15-ax243dx Screen Replacement: step 4, image 1 of 2 HP Omen 15-ax243dx Screen Replacement: step 4, image 2 of 2
      • Pull the battery cable out from its motherboard socket.
      • Pull parallel to the motherboard, not straight up.
      • Remove the battery.
      • Disconnect the power cord from the battery and transfer it to your replacement battery.
      Ask FixBot
    1. HP Omen 15-ax243dx Screen Replacement, Screen: step 5, image 1 of 2 HP Omen 15-ax243dx Screen Replacement, Screen: step 5, image 2 of 2
      • Unscrew the six 1.2 mm screws connecting the screen to the body using the #00 Phillips screwdriver head.
      • Be cautious of where the screws come out from, some will only fit in the same location.
      Ask FixBot
    2. HP Omen 15-ax243dx Screen Replacement: step 6, image 1 of 3 HP Omen 15-ax243dx Screen Replacement: step 6, image 2 of 3 HP Omen 15-ax243dx Screen Replacement: step 6, image 3 of 3
      • Remove the tape holding the wires down
      • Disconnect the wires from the wifi chip
      • When removing the wires from the wifi chip, be careful to not damage the connectors.
      Ask FixBot
    3. HP Omen 15-ax243dx Screen Replacement: step 7, image 1 of 3 HP Omen 15-ax243dx Screen Replacement: step 7, image 2 of 3 HP Omen 15-ax243dx Screen Replacement: step 7, image 3 of 3
      • Flip the switch up that holds the screen cable in place
      • Lift up and pull back the cable from the insert
      Ask FixBot
    4. HP Omen 15-ax243dx Screen Replacement: step 8, image 1 of 2 HP Omen 15-ax243dx Screen Replacement: step 8, image 2 of 2
      • Lift the base of the device up to separate the hinges from the body of the device
      Ask FixBot
    5. HP Omen 15-ax243dx Screen Replacement: step 9, image 1 of 1
      • Slide the base of the device out from under the hinges
      • The screen can now be replaced
      Ask FixBot
vangnam
599 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 25
Past 30 Days: 143
All Time: 6,472
