HP Omen 15 2020-2021 RAM Replacement
    1. HP Omen 15 2020-2021 RAM Replacement, Preparation: step 1, image 1 of 1
      Tool used on this step:
      Anti-Static Wrist Strap
      $7.95
      Buy
      • Make sure the laptop is completely turned off. To properly turn it off, hold the power button for a few seconds until it turns off.
      • Unplug everything from the computer(USB, HDMI, Charger).
      • It's always preferable to use an anti-static strap or mat.
      Ask FixBot
    2. HP Omen 15 2020-2021 RAM Replacement, Removing screws: step 2, image 1 of 1
      • Put your laptop on a soft surface (preferably a mouse mat but never on a carpet) so as not to scratch the lid.
      • Flip the laptop like in the picture and locate the 8 screws (4 in the front and 4 in the back).
      • Don't forget that the 4 front screws are shorter than the 4 back screws.
      Ask FixBot
    3. HP Omen 15 2020-2021 RAM Replacement, Removing the back cover: step 3, image 1 of 1
      • Use a pry tool to remove the cover by going slowly around the laptop.
      Ask FixBot
    4. HP Omen 15 2020-2021 RAM Replacement, Removing the RAM: step 4, image 1 of 3 HP Omen 15 2020-2021 RAM Replacement, Removing the RAM: step 4, image 2 of 3 HP Omen 15 2020-2021 RAM Replacement, Removing the RAM: step 4, image 3 of 3
      • Locate the RAM.
      • Put your fingers on the two silver parts and push to the side. The RAM should pop out like in the picture.
      Ask FixBot
    5. HP Omen 15 2020-2021 RAM Replacement, Installing the new RAM: step 5, image 1 of 1
      • When putting the new ram, make sure it lines up well. If it's taking too much force to insert then it's probably going in the wrong way.
      Ask FixBot
    6. HP Omen 15 2020-2021 RAM Replacement, Reassembly: step 6, image 1 of 1
      • Put back the bottom panel and make sure to screw the short screws in the front and the long ones in the back.
      Ask FixBot
    7. HP Omen 15 2020-2021 RAM Replacement, Make sure everything works: step 7, image 1 of 1
      Ask FixBot
Finish Line
youssef oumlil
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 44
All Time: 1,691
