HP Officejet Pro 8625 Printhead Replacement
  1. HP Officejet Pro 8625 Printhead Replacement, Left Side Panel: step 1, image 1 of 3 HP Officejet Pro 8625 Printhead Replacement, Left Side Panel: step 1, image 2 of 3 HP Officejet Pro 8625 Printhead Replacement, Left Side Panel: step 1, image 3 of 3
    • Remove the two 11.6 mm T9 screws from the right side of the back of the printer.
    Ask FixBot
  2. HP Officejet Pro 8625 Printhead Replacement: step 2, image 1 of 3 HP Officejet Pro 8625 Printhead Replacement: step 2, image 2 of 3 HP Officejet Pro 8625 Printhead Replacement: step 2, image 3 of 3
    • Pull down the front panel to expose the screws on the front.
    • Remove the one 11.6 mm T9 screw on the left side of the front face.
    Ask FixBot
  3. HP Officejet Pro 8625 Printhead Replacement: step 3, image 1 of 2 HP Officejet Pro 8625 Printhead Replacement: step 3, image 2 of 2
    • Remove the side panel by pushing down and towards the back.
    • This step may be easier if the printer is laid on its side with the left side panel facing up.
    Ask FixBot
  4. HP Officejet Pro 8625 Printhead Replacement, Printhead: step 4, image 1 of 2 HP Officejet Pro 8625 Printhead Replacement, Printhead: step 4, image 2 of 2
    • Remove the one 5.3 mm T9 screw.
    Ask FixBot
  5. HP Officejet Pro 8625 Printhead Replacement: step 5, image 1 of 2 HP Officejet Pro 8625 Printhead Replacement: step 5, image 2 of 2
    • Remove the four connectors from the top of the motherboard.
    Ask FixBot
  6. HP Officejet Pro 8625 Printhead Replacement: step 6, image 1 of 2 HP Officejet Pro 8625 Printhead Replacement: step 6, image 2 of 2
    • Remove the three 11.6 mm T9 screws from the top, back of the printer.
    • Remove the one 12.1 mm T9 screw from the top, back of the printer.
    Ask FixBot
  7. HP Officejet Pro 8625 Printhead Replacement: step 7, image 1 of 2 HP Officejet Pro 8625 Printhead Replacement: step 7, image 2 of 2
    • Remove the 11.6mm T9 screw from the top left of the front of the printer.
    Ask FixBot
  8. HP Officejet Pro 8625 Printhead Replacement: step 8, image 1 of 1
    • Disconnect the display by pulling down on the plastic hinge.
    • Gradually apply more force to the hinge and don't worry about the hinge or display breaking.
    Ask FixBot
  9. HP Officejet Pro 8625 Printhead Replacement: step 9, image 1 of 3 HP Officejet Pro 8625 Printhead Replacement: step 9, image 2 of 3 HP Officejet Pro 8625 Printhead Replacement: step 9, image 3 of 3
    • Lift the display as high as it will allow to expose the back of the display.
    • Remove the connector by pinching the sides and pulling away from the printer.
    • Remove the connector by pulling both away from the display and towards the printer.
    Ask FixBot
  10. HP Officejet Pro 8625 Printhead Replacement: step 10, image 1 of 2 HP Officejet Pro 8625 Printhead Replacement: step 10, image 2 of 2
    • Remove the two 11.6 mm T9 screws from beneath the display.
    Ask FixBot
  11. HP Officejet Pro 8625 Printhead Replacement: step 11, image 1 of 1
    • Remove the top of the printer by lifting it from both sides.
    Ask FixBot
  12. HP Officejet Pro 8625 Printhead Replacement: step 12, image 1 of 3 HP Officejet Pro 8625 Printhead Replacement: step 12, image 2 of 3 HP Officejet Pro 8625 Printhead Replacement: step 12, image 3 of 3
    • Locate the printhead on the right side of the printer.
    • Pull the white tab on the right side of the printhead up, by pushing on the side of the printer a little bit.
    • Remove the printhead by lifting it out of the housing.
    Ask FixBot
7 other people completed this guide.
Cam Engle
555 Reputation
3 Guides authored
Cal Poly, Team S13-G3, White Fall 2018 Member of Cal Poly, Team S13-G3, White Fall 2018
CPSU-WHITE-F18S13G3
3 Members
14 Guides authored
8 Guide Comments
This printhead is normally user replaceable.
No screwdrivers are required.
This video is for an 8600, but the process is the same.
https://www.youtube.com/watch?v=i-IluLvF...
Andy - Reply Share
I used these instructions to repair the guide ribbon for the print head. It had come off after a sheet of high tack labels got jammed in the printer. Just saved myself from having to buy a new printer! Thanks!!!
Robert de Salazar - Reply Share
12 steps not necessary. Just open the front (like changing ink) and lift the grey lever referenced in step 12, then remove the head from the carriage.
bwaaronj - Reply Share
Correct. So easy.
hinz - Reply Share
BWAARONJ, I did exactly what you suggested in my 8625 three times! Now my printer is in pieces and parts, and I cannot get the printhead to release from the right side of the housing. I was very meticulous in making an effort to correct this problem, but, alas, it appears I will have to get a new printer!
Shelia Guy Bozeman - Reply Share
Past 24 Hours: 4
Past 7 Days: 10
Past 30 Days: 66
All Time: 9,525
