HP Officejet Pro 8620 Printer Head Replacement
  1. HP Officejet Pro 8620 Printer Head Replacement, Printer Head: step 1, image 1 of 1
    • Open the printer head cover door by pulling the cover door.
    • Power on the printer. This will move the print head to the left so you can access it.
    • Unplug the power cable from the back of the printer.
    • Do not power down the printer using the power button, as this will cause the printhead to move back to the right, making it incaccessible.
    Ask FixBot
  2. HP Officejet Pro 8620 Printer Head Replacement: step 2, image 1 of 2 HP Officejet Pro 8620 Printer Head Replacement: step 2, image 2 of 2
    • Locate the printer head on the left side of the printer.
    Ask FixBot
  3. HP Officejet Pro 8620 Printer Head Replacement: step 3, image 1 of 2 HP Officejet Pro 8620 Printer Head Replacement: step 3, image 2 of 2
    • Pull the white plastic tab on the right of the printhead toward you on an upward swing to unlock the printhead.
    Ask FixBot
  4. HP Officejet Pro 8620 Printer Head Replacement: step 4, image 1 of 2 HP Officejet Pro 8620 Printer Head Replacement: step 4, image 2 of 2
    • Gently pull out the printer head.
    Ask FixBot
16 other people completed this guide.
Scott
656 Reputation
3 Guides authored
Cal Poly, Team S19-G2, Livingston Spring 2018 Member of Cal Poly, Team S19-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S19G2
1 Member
6 Guides authored
17 Guide Comments
Did not work for me on my HP 8620.
Sam Cauchi - Reply Share
Do you sell the replacement print head box for the HP Officejet pro 8620?
Do you post to England?
Thanks Pat Trotter
Pat Trotter - Reply Share
How about always paperjam and printhead just moving by 1 inch
Setiawan Ayooservice - Reply Share
Replacing easy.
BUT. Can it be repaired? Someone real experience with it?
PS. Of course only as no physical damage from outside and all 4 ink chambers (1) still sealed properly and (2) never have run empty
lbruederlin - Reply Share
Did not work for me. Followed the instruction and re installed the printhead. Same issue.
abenani2000 - Reply Share
Past 24 Hours: 5
Past 7 Days: 53
Past 30 Days: 181
All Time: 29,321
