HP Officejet Pro 8620 Power Button Replacement
    1. HP Officejet Pro 8620 Power Button Replacement, Power Button: step 1, image 1 of 3 HP Officejet Pro 8620 Power Button Replacement, Power Button: step 1, image 2 of 3 HP Officejet Pro 8620 Power Button Replacement, Power Button: step 1, image 3 of 3
      • Locate the power button on the bottom left side of the device.
      • Wedge the opening tool into the small gap between the power button panel and printer.
      • Apply pressure on the opening tool and open the power button panel.
      • Gently remove the power button panel assembly from the printer to access the power button.
      Ask FixBot
    2. HP Officejet Pro 8620 Power Button Replacement: step 2, image 1 of 2 HP Officejet Pro 8620 Power Button Replacement: step 2, image 2 of 2
      • Press on the power button from the front of the panel to release it.
      Ask FixBot
    3. HP Officejet Pro 8620 Power Button Replacement: step 3, image 1 of 2 HP Officejet Pro 8620 Power Button Replacement: step 3, image 2 of 2
      • Turn the panel around so you are viewing the back of it.
      • Disconnect the power button from the panel by gently pulling the button out (toward your body).
      • Be careful not to crack the connector of the button panel when pulling the power button
      Ask FixBot
Scott
656 Reputation
3 Guides authored
Cal Poly, Team S19-G2, Livingston Spring 2018 Member of Cal Poly, Team S19-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S19G2
1 Member
36 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 25
All Time: 3,206
