HP Officejet Pro 8620 Display Replacement
Views: 6K
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
102
All Time:
6,044
Comments: 1
1 comment on steps.
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Follow this guide to remove a faulty display in your HP Officejet Pro 8620. If the touch-screen display is unresponsive, has image burn in, or stuck pixels you will need to replace the display.
Tools
    1. HP Officejet Pro 8620 Display Replacement, Display: step 1, image 1 of 2 HP Officejet Pro 8620 Display Replacement, Display: step 1, image 2 of 2
      • Place the printer on its back and rotate the display clockwise to gain access to the underside of the display.
      Ask FixBot
    2. HP Officejet Pro 8620 Display Replacement: step 2, image 1 of 3 HP Officejet Pro 8620 Display Replacement: step 2, image 2 of 3 HP Officejet Pro 8620 Display Replacement: step 2, image 3 of 3
      • Locate the control arm on the underside of the display. You will need to detach this to access the screws.
      • Place a finger behind the control arm.
      • Separate the display unit from the control arm by pulling down with your finger and using your other hand to push the display unit up.
      • Removing the control arm takes a moderate amount of force.
      Ask FixBot
    3. HP Officejet Pro 8620 Display Replacement: step 3, image 1 of 3 HP Officejet Pro 8620 Display Replacement: step 3, image 2 of 3 HP Officejet Pro 8620 Display Replacement: step 3, image 3 of 3
      • Remove the four 11mm T9-Torx screws on the underside of the display unit by rotating the screwdriver counter clockwise.
      • Open the display unit to expose the circuit board by separating the back and front panels.
      • Remove the ribbon cable by gently releasing the plastic locking mechanism and pulling the cable away from the circuit board.
      Ask FixBot
    4. HP Officejet Pro 8620 Display Replacement: step 4, image 1 of 2 HP Officejet Pro 8620 Display Replacement: step 4, image 2 of 2
      • Remove the four 7mm T9-Torx screws from the circuit board that are holding the screen in place using a T9-Torx screwdriver and turning counter clockwise.
      • Lift the circuit board/screen panel from the black frame.
      Ask FixBot
4 other people completed this guide.
Dallas Rocha
243 Reputation
1 Guide authored
Cal Poly, Team S19-G2, Livingston Winter 2018 Member of Cal Poly, Team S19-G2, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G2
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 102
All Time: 6,044
