HP Officejet Pro 8600 Plus Battery Replacement
  1. HP Officejet Pro 8600 Plus Battery Replacement, Motherboard: step 1, image 1 of 2 HP Officejet Pro 8600 Plus Battery Replacement, Motherboard: step 1, image 2 of 2
    • Turn the printer so the back is facing you.
    • Put the printer in a vertical position by lifting its right side.
    Ask FixBot
  2. HP Officejet Pro 8600 Plus Battery Replacement: step 2, image 1 of 1
    • Remove the two 12mm T10 Torx screws on the top edge of the printer.
    Ask FixBot
  3. HP Officejet Pro 8600 Plus Battery Replacement: step 3, image 1 of 1
    • Rotate the printer clockwise so the bottom of the printer is facing you.
    Ask FixBot
  4. HP Officejet Pro 8600 Plus Battery Replacement: step 4, image 1 of 2 HP Officejet Pro 8600 Plus Battery Replacement: step 4, image 2 of 2
    • Insert the plastic opening tool underneath the slot on the right that aligns with the edge of the back panel.
    • Insert a second plastic opening tool in the notch lining up with the crease in the back panel.
    • This step requires applying a significant amount of force on the left notch. Don't be alarmed if you hear popping noises.
    Ask FixBot
  5. HP Officejet Pro 8600 Plus Battery Replacement: step 5, image 1 of 1
    • Remove the side panel from the printer by lifting upwards toward you.
    • For reassembly, slide the side panel from left to right into place.
    Ask FixBot
  6. HP Officejet Pro 8600 Plus Battery Replacement: step 6, image 1 of 1
    • Remove the four 6.5 mm T10 Torx screws from the motherboard.
    Ask FixBot
  7. HP Officejet Pro 8600 Plus Battery Replacement: step 7, image 1 of 1
    • Remove the black brace from the right side of the motherboard, located near the black ribbon cable.
    Ask FixBot
  8. HP Officejet Pro 8600 Plus Battery Replacement: step 8, image 1 of 3 HP Officejet Pro 8600 Plus Battery Replacement: step 8, image 2 of 3 HP Officejet Pro 8600 Plus Battery Replacement: step 8, image 3 of 3
    • Remove the cables connected to the top of the motherboard by gently pulling them out of their ports.
    • Remove the cables connected to the edge of the motherboard by gently pulling them out of their ports.
    • Remove the cables connected to the underside of the motherboard by gently pulling them out of their ports.
    Ask FixBot
  9. HP Officejet Pro 8600 Plus Battery Replacement, Battery: step 9, image 1 of 2 HP Officejet Pro 8600 Plus Battery Replacement, Battery: step 9, image 2 of 2
    • Turn the motherboard over so the back is facing upward.
    • Use the plastic opening tool to pry the battery out of place.
    Ask FixBot
  10. HP Officejet Pro 8600 Plus Battery Replacement: step 10, image 1 of 1
    • Remove the battery by grabbing its edges, lifting upward, and sliding sideways.
    Ask FixBot
11 other people completed this guide.
Mackinnon Buck
1,320 Reputation
3 Guides authored
Cal Poly, Team S16-G4, Livingston Spring 2018 Member of Cal Poly, Team S16-G4, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G4
4 Members
11 Guides authored
3 Guide Comments
Are there any procedures required after either battery replacement or motherboard replacement? Re-loading of firmware, initialization, etc. Does the printer's serial number change as a result of battery replacement or motherboard replacement?
Erik Fjerstad - Reply Share
Bonjour ,
ma batterie est ok , par contre la courroie s'effiloche.
Peut on la remplacer et si oui comment y accéder?
J'ai déplacé le tendeur pour augmenter la tension de la courroie mais ce n'est pas suffisant.
Merci
BàV phil
Philippe Herbots - Reply Share
Bonjour, Merci beaucoup pour ce dépannage clair, sur la HP8610 Office jet Pro, cela m'a permis de régler aussi le problème du message système défectueux en enlevant la pile et la remettant. C'est un peu différent de la 8600. Une 3ème vis à enlever sur l'avant avant d'enlever le panneau latéral gauche. Pour accéder à la 3ème vis sur la gauche, il faut ouvrir le clapet d'accès aux cartouches, c'est tout. Et ne pas oublier de bien reconnecter les connectiques (j'avais zappé le câble du bac ADF, qui n'était plus détecté du coup...). La manip est simple et c'est reparti pour 5 ans !
Ander - Reply Share
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 68
All Time: 6,946
