HP Officejet J3680 Keypad Motherboard Replacement
  1. HP Officejet J3680 Keypad Motherboard Replacement, Unplug the Device: step 1, image 1 of 1
    • Remove the plug from the outlet and from the back of the device
    • Remove the USB Cable from your computer and from the back of the device.
    Ask FixBot
  2. HP Officejet J3680 Keypad Motherboard Replacement, Remove Screws From Under the Control Panel: step 2, image 1 of 1
    • Using your Torx T10 screwdriver, remove the screws indicated in the picture. Screws are 13mm in length.
    Ask FixBot
  3. HP Officejet J3680 Keypad Motherboard Replacement, Remove Screws Underneath the Ink Cartridge Cover: step 3, image 1 of 1
    Ask FixBot
  4. HP Officejet J3680 Keypad Motherboard Replacement, Remove Screws from Underneath the Phone Panel: step 4, image 1 of 1
    • In step 2, you removed the screw from the blue indicated area.
    • Gently pop off the black cover that the phone rests on. Underneath this cover, you will find two more screws.
    Ask FixBot
  5. HP Officejet J3680 Keypad Motherboard Replacement, Remove the Screws from the Rear of Device: step 5, image 1 of 1
    Ask FixBot
  6. HP Officejet J3680 Keypad Motherboard Replacement, Remove Rear Plastic Panel: step 6, image 1 of 1
    • Once the rear plastic panel has been removed, you are ready to replace and repair the necessary parts.
    Ask FixBot
  7. HP Officejet J3680 Keypad Motherboard Replacement, Pry off the panel with the hp logo: step 7, image 1 of 1
    • Using the plastic opening tool, Pry off the front black plastic panel on screen area. This panel has the HP symbol on the front.
    Ask FixBot
  8. HP Officejet J3680 Keypad Motherboard Replacement, Unscrew and remove panel: step 8, image 1 of 1
    • Using the T10 Torx screwdriver, unscrew the 7 screws on the panel indicated in the picture. These screws are 13mm in length.
    • Then, remove this panel.
    Ask FixBot
  9. HP Officejet J3680 Keypad Motherboard Replacement, remove rubber buttons: step 9, image 1 of 2 HP Officejet J3680 Keypad Motherboard Replacement, remove rubber buttons: step 9, image 2 of 2
    • Pull off the rubber buttons. This will come off easily.
    • You will see the green motherboard underneath.
    Ask FixBot
  10. HP Officejet J3680 Keypad Motherboard Replacement, Remove black paper tray: step 10, image 1 of 1
    • Remove black paper tray by pulling it straight out. If you are standing directly in front of it, you will be pulling it toward you.
    Ask FixBot
  11. HP Officejet J3680 Keypad Motherboard Replacement, Disconnect front panel from printer: step 11, image 1 of 3 HP Officejet J3680 Keypad Motherboard Replacement, Disconnect front panel from printer: step 11, image 2 of 3 HP Officejet J3680 Keypad Motherboard Replacement, Disconnect front panel from printer: step 11, image 3 of 3
    • Pull off the entire black front panel (where the motherboard rest on) by unfolding it forward (as if you’re fixing a paper jam) and pull it forward until it pops off.
    • Begin with the right side first. Once the right side is free, do the same on the left side.
    Ask FixBot
  12. HP Officejet J3680 Keypad Motherboard Replacement, Unplug keypad motherboard from the main motherboard: step 12, image 1 of 1
    • Follow the wires from the left side of the keypad motherboard (on the panel you just removed) to the main motherboard and carefully unplug the wires from the main motherboard (located in the upper left corner.)
    Ask FixBot
  13. HP Officejet J3680 Keypad Motherboard Replacement, Slip wires through the hole in the bottom left corner of the printer.: step 13, image 1 of 1
    • Wiggle wires through the hole in the bottom left corner of the printer so that the keypad motherboard panel disconnects completely from the printer.
    • To easily fit it through the hole, turn the white piece at the tip of the wires horizontally.
    Ask FixBot
  14. HP Officejet J3680 Keypad Motherboard Replacement, Disconnect green motherboard from panel: step 14, image 1 of 2 HP Officejet J3680 Keypad Motherboard Replacement, Disconnect green motherboard from panel: step 14, image 2 of 2
    • Finally, pull wires upward, where the black tape on the wires is.
    • The green motherboard will become disconnected from the panel.
    Ask FixBot
  15. HP Officejet J3680 Keypad Motherboard Replacement, Reverse steps to install new keypad motherboard: step 15, image 1 of 1
    • Reverse the steps to replace your new keypad motherboard.
    Ask FixBot
Ashley Beauchemin
113 Reputation
1 Guide authored
UMass Dartmouth, Team 1-1, Duarte Fall 2014 Member of UMass Dartmouth, Team 1-1, Duarte Fall 2014
UMASSD-DUARTE-F14S1G1
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 21
All Time: 824
