HP Officejet 6700 Paper Feed Fix
Video Overview
    • This video shows you exactly what the problem with paper not feeding is. In it you can see the drive shaft turning and sometimes driving the attached gear, but at the point where it tries to actually move the paper where the gear encounters resistance, the shaft just spins without driving the gear.
    Ask FixBot
  1. HP Officejet 6700 Paper Feed Fix, Remove the paper tray lid: step 2, image 1 of 3 HP Officejet 6700 Paper Feed Fix, Remove the paper tray lid: step 2, image 2 of 3 HP Officejet 6700 Paper Feed Fix, Remove the paper tray lid: step 2, image 3 of 3
    • Lift the paper tray cover slightly.
    • Pull straight forward to detach the cover.
    • Remove all but a couple of sheets of paper from the tray to give yourself room to work. Leaving a sheet or two will catch any drips of glue that might happen.
    Ask FixBot
  2. HP Officejet 6700 Paper Feed Fix, Set up your mirror and light: step 3, image 1 of 1
    • Position your mirror under the gear and adjust it until you have a good view of the gear.
    • A flashlight in front of the mirror will light the space.
    Ask FixBot
  3. HP Officejet 6700 Paper Feed Fix, Slide the gear off the splines: step 4, image 1 of 2 HP Officejet 6700 Paper Feed Fix, Slide the gear off the splines: step 4, image 2 of 2
    • A pair of curved hemostats work very well here; use them to get hold of the gear; it's tricky working upside down and in a mirror, but be patient and you'll get it.
    • Slide the gear to the left, exposing the splines.
    Ask FixBot
  4. HP Officejet 6700 Paper Feed Fix, Locate the shaft gear: step 5, image 1 of 1
    • At the end of my finger just in front of the screw visible near the front of the opening is a gear that can be rotated by hand. You'll need to turn this gear to expose all sides of the splines so they can be coated with epoxy.
    • The gear only turns one direction, so if it doesn't turn easily, try the other direction.
    Ask FixBot
  5. HP Officejet 6700 Paper Feed Fix, Mix up your epoxy: step 6, image 1 of 3 HP Officejet 6700 Paper Feed Fix, Mix up your epoxy: step 6, image 2 of 3 HP Officejet 6700 Paper Feed Fix, Mix up your epoxy: step 6, image 3 of 3
    • Squeeze out equal portions of resin and catalyst.
    • Mix well.
    • This is what mine looks like when it's mixed.
    Ask FixBot
  6. HP Officejet 6700 Paper Feed Fix, Apply the epoxy: step 7, image 1 of 1
    • Using your toothpick, get a small blob of epoxy on the end, then apply it to the splines.
    • Rotate the drive shaft to expose uncoated splines, then add more epoxy.
    • Repeat until the entire circumference of the splines are coated.
    • Depending on your epoxy, you may need to work quickly so the epoxy doesn't have time to set up before you're done.
    Ask FixBot
  7. HP Officejet 6700 Paper Feed Fix, Move the gear back into place: step 8, image 1 of 1
    • Using your hemostats, slide the gear back onto the splines before the glue dries.
    • You may have to rotate the gear slightly to match up the teeth with the gear it drives, so if it doesn't slide over immediately, give it a slight turn and try again.
    Ask FixBot
Follow the instructions on the epoxy regarding drying time, then you can use your printer again!
Jerry Wheeler
97,883 Reputation
92 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 50
All Time: 234
