HP Officejet 4630 Scanner Head Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
6
Past 7 Days:
24
Past 30 Days:
96
All Time:
2,214
Comments: 4
4 comments on steps.
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
The scanner head is necessary for copying and faxing. Follow the guide to replace this crucial part.
Tools
    1. HP Officejet 4630 Scanner Head Replacement, LCD Display: step 1, image 1 of 3 HP Officejet 4630 Scanner Head Replacement, LCD Display: step 1, image 2 of 3 HP Officejet 4630 Scanner Head Replacement, LCD Display: step 1, image 3 of 3
      • There is a hidden screw underneath the model sticker on the front panel.
      • Peel the model sticker off the cover.
      • This will expose the T10 screw securing the panel.
      Ask FixBot
    2. HP Officejet 4630 Scanner Head Replacement: step 2, image 1 of 3 HP Officejet 4630 Scanner Head Replacement: step 2, image 2 of 3 HP Officejet 4630 Scanner Head Replacement: step 2, image 3 of 3
      • Remove the single 12mm-T10 screw securing the front panel to the printer body.
      • Loosen the panel cover from the printer body.
      • There is a ribbon cable connected to the backside of the cover. Disconnect the cable before separating the panel completely.
      Ask FixBot
    3. HP Officejet 4630 Scanner Head Replacement: step 3, image 1 of 3 HP Officejet 4630 Scanner Head Replacement: step 3, image 2 of 3 HP Officejet 4630 Scanner Head Replacement: step 3, image 3 of 3
      • Gently remove the No-Fuss ribbon cable from the front panel.
      Ask FixBot
    4. HP Officejet 4630 Scanner Head Replacement: step 4, image 1 of 3 HP Officejet 4630 Scanner Head Replacement: step 4, image 2 of 3 HP Officejet 4630 Scanner Head Replacement: step 4, image 3 of 3
      • Remove the seven 8mm screws using the Torx T6 screwdriver.
      • Remove the motherboard from the front-panel housing.
      • The LCD display is on the opposite side.
      Ask FixBot
    1. HP Officejet 4630 Scanner Head Replacement, Power Supply: step 5, image 1 of 3 HP Officejet 4630 Scanner Head Replacement, Power Supply: step 5, image 2 of 3 HP Officejet 4630 Scanner Head Replacement, Power Supply: step 5, image 3 of 3
      • Lift the hood of the printer.
      Ask FixBot
    2. HP Officejet 4630 Scanner Head Replacement: step 6, image 1 of 3 HP Officejet 4630 Scanner Head Replacement: step 6, image 2 of 3 HP Officejet 4630 Scanner Head Replacement: step 6, image 3 of 3
      • Remove the two T10 11mm screws.
      Ask FixBot
    3. HP Officejet 4630 Scanner Head Replacement: step 7, image 1 of 3 HP Officejet 4630 Scanner Head Replacement: step 7, image 2 of 3 HP Officejet 4630 Scanner Head Replacement: step 7, image 3 of 3
      • Remove the panels covering the power brick and cord.
      Ask FixBot
    4. HP Officejet 4630 Scanner Head Replacement: step 8, image 1 of 2 HP Officejet 4630 Scanner Head Replacement: step 8, image 2 of 2
      • Remove the cord from the power supply.
      Ask FixBot
    5. HP Officejet 4630 Scanner Head Replacement: step 9, image 1 of 3 HP Officejet 4630 Scanner Head Replacement: step 9, image 2 of 3 HP Officejet 4630 Scanner Head Replacement: step 9, image 3 of 3
      • Slide the power supply out from the chassis.
      • The power supply is still attached; don't pull too quickly.
      Ask FixBot
    6. HP Officejet 4630 Scanner Head Replacement: step 10, image 1 of 1
      • Remove final cable from power supply.
      Ask FixBot
    1. HP Officejet 4630 Scanner Head Replacement, Scanner Head: step 11, image 1 of 1
      • Remove eight T10 1mm screws from the top hood of the printer.
      Ask FixBot
    2. HP Officejet 4630 Scanner Head Replacement: step 12, image 1 of 3 HP Officejet 4630 Scanner Head Replacement: step 12, image 2 of 3 HP Officejet 4630 Scanner Head Replacement: step 12, image 3 of 3
      • Use the nylon spudger to pry the tab.
      • Lift up the entire panel.
      Ask FixBot
    3. HP Officejet 4630 Scanner Head Replacement: step 13, image 1 of 3 HP Officejet 4630 Scanner Head Replacement: step 13, image 2 of 3 HP Officejet 4630 Scanner Head Replacement: step 13, image 3 of 3
      • Lift and flip the entire panel.
      • Be aware of the scanner head attached to the panel.
      Ask FixBot
    4. HP Officejet 4630 Scanner Head Replacement: step 14, image 1 of 3 HP Officejet 4630 Scanner Head Replacement: step 14, image 2 of 3 HP Officejet 4630 Scanner Head Replacement: step 14, image 3 of 3
      • Start with the scanner head in place.
      • Unwind the ribbon from the track.
      • Detach ribbon completely.
      Ask FixBot
Maya Willis
424 Reputation
3 Guides authored
Cal Poly, Team S18-G3, Livingston Winter 2018 Member of Cal Poly, Team S18-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G3
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 24
Past 30 Days: 96
All Time: 2,214
