HP Officejet 4630 Paper Tray Replacement
  1. HP Officejet 4630 Paper Tray Replacement, Paper Tray: step 1, image 1 of 1
    • Begin by turning your printer upside down.
    • It can be helpful to position an object beneath the printer to keep it level while you work on it.
    Ask FixBot
  2. HP Officejet 4630 Paper Tray Replacement: step 2, image 1 of 1
    • Use the T-10 screwdriver to remove the two 11-mm screws.
    Ask FixBot
  3. HP Officejet 4630 Paper Tray Replacement: step 3, image 1 of 1
    • Pull the paper tray out until it hits the stops on either side of the tray.
    Ask FixBot
  4. HP Officejet 4630 Paper Tray Replacement: step 4, image 1 of 3 HP Officejet 4630 Paper Tray Replacement: step 4, image 2 of 3 HP Officejet 4630 Paper Tray Replacement: step 4, image 3 of 3
    • Lift up on one side of the black plastic bar with one hand while pulling the paper tray out of the printer with your other hand.
    • The side of the tray should slide away from the printer a little bit.
    Ask FixBot
  5. HP Officejet 4630 Paper Tray Replacement: step 5, image 1 of 2 HP Officejet 4630 Paper Tray Replacement: step 5, image 2 of 2
    • Repeat the previous step but for the other side of the tray.
    Ask FixBot
  6. HP Officejet 4630 Paper Tray Replacement: step 6, image 1 of 1
    • The paper tray should now be free to slide away from the printer.
    Ask FixBot
5 other people completed this guide.
Tyler Allen
513 Reputation
2 Guides authored
Cal Poly, Team S18-G3, Livingston Winter 2018 Member of Cal Poly, Team S18-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G3
4 Members
18 Guides authored
1 Guide Comment
merci pour l info!
devaux - Reply Share
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 31
All Time: 2,440
