HP Officejet 4630 LCD Display Replacement
  1. HP Officejet 4630 LCD Display Replacement, LCD Display: step 1, image 1 of 3 HP Officejet 4630 LCD Display Replacement, LCD Display: step 1, image 2 of 3 HP Officejet 4630 LCD Display Replacement, LCD Display: step 1, image 3 of 3
    • There is a hidden screw underneath the model sticker on the front panel.
    • Peel the model sticker off the cover.
    • This will expose the T10 screw securing the panel.
    Ask FixBot
  2. HP Officejet 4630 LCD Display Replacement: step 2, image 1 of 3 HP Officejet 4630 LCD Display Replacement: step 2, image 2 of 3 HP Officejet 4630 LCD Display Replacement: step 2, image 3 of 3
    • Remove the single 12mm-T10 screw securing the front panel to the printer body.
    • Loosen the panel cover from the printer body.
    • There is a ribbon cable connected to the backside of the cover. Disconnect the cable before separating the panel completely.
    Ask FixBot
  3. HP Officejet 4630 LCD Display Replacement: step 3, image 1 of 3 HP Officejet 4630 LCD Display Replacement: step 3, image 2 of 3 HP Officejet 4630 LCD Display Replacement: step 3, image 3 of 3
    • Gently remove the No-Fuss ribbon cable from the front panel.
    Ask FixBot
  4. HP Officejet 4630 LCD Display Replacement: step 4, image 1 of 3 HP Officejet 4630 LCD Display Replacement: step 4, image 2 of 3 HP Officejet 4630 LCD Display Replacement: step 4, image 3 of 3
    • Remove the seven 8mm screws using the Torx T6 screwdriver.
    • Remove the motherboard from the front-panel housing.
    • The LCD display is on the opposite side.
    Ask FixBot
2 other people completed this guide.
Justin Engwall
158 Reputation
1 Guide authored
Cal Poly, Team S18-G3, Livingston Winter 2018 Member of Cal Poly, Team S18-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G3
4 Members
18 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 10
Past 30 Days: 47
All Time: 2,181
