Up to 20% off select tools
HP OfficeJet 4650 Power Button Replacement
Views: 4.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
27
Past 30 Days:
132
All Time:
4,759
Comments: 6
6 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 6 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The power button is what allows the printer to turn on. If the power button is malfunctioning, the HP OfficeJet 4650 will not function. This guide will show you how to replace the power button.
    1. HP OfficeJet 4650 Power Button Replacement, Power Button: step 1, image 1 of 3 HP OfficeJet 4650 Power Button Replacement, Power Button: step 1, image 2 of 3 HP OfficeJet 4650 Power Button Replacement, Power Button: step 1, image 3 of 3
      • Open the cartridge access door by putting one hand on the grooves of each side and pulling up.
      Ask FixBot
    2. HP OfficeJet 4650 Power Button Replacement: step 2, image 1 of 2 HP OfficeJet 4650 Power Button Replacement: step 2, image 2 of 2
      • Using the 2.0 mm hex screwdriver, remove the 14 mm hex screw that binds the front cover to the printer body by turning the screw counterclockwise.
      Ask FixBot
    3. HP OfficeJet 4650 Power Button Replacement: step 3, image 1 of 3 HP OfficeJet 4650 Power Button Replacement: step 3, image 2 of 3 HP OfficeJet 4650 Power Button Replacement: step 3, image 3 of 3
      • Release the front panel from its internal hooks by applying a little force and sliding the front panel to the right.
      • Push the panel upward to remove it from the printer.
      • There is a connector attached to the back of the panel. Flip the front cover towards you gently and proceed to the next step.
      Ask FixBot
    4. HP OfficeJet 4650 Power Button Replacement: step 4, image 1 of 3 HP OfficeJet 4650 Power Button Replacement: step 4, image 2 of 3 HP OfficeJet 4650 Power Button Replacement: step 4, image 3 of 3
      • Remove the connector that is attached to the screen's circuit board by pinching the blue part of the connector with two fingers and pulling it away from the circuit board.
      Ask FixBot
    5. HP OfficeJet 4650 Power Button Replacement: step 5, image 1 of 3 HP OfficeJet 4650 Power Button Replacement: step 5, image 2 of 3 HP OfficeJet 4650 Power Button Replacement: step 5, image 3 of 3
      • Using the Torx T6 hex screwdriver, remove the 7.0mm screw that binds the front cover to the printer body by turning the screw counterclockwise.
      Ask FixBot
    6. HP OfficeJet 4650 Power Button Replacement: step 6, image 1 of 3 HP OfficeJet 4650 Power Button Replacement: step 6, image 2 of 3 HP OfficeJet 4650 Power Button Replacement: step 6, image 3 of 3
      • Remove the connector that is attached to the screen's circuit board by pinching the blue part of the connector with two fingers and pulling it away from button circuit board.
      Ask FixBot
    7. HP OfficeJet 4650 Power Button Replacement: step 7, image 1 of 3 HP OfficeJet 4650 Power Button Replacement: step 7, image 2 of 3 HP OfficeJet 4650 Power Button Replacement: step 7, image 3 of 3
      • Pop the button off from the black cover by using your finger tip to bring it up.
      Ask FixBot
Author
with
Stephanie Carpintero
1,021 Reputation
5 Guides authored
Cal Poly, Team S19-G6, Livingston Winter 2018 Member of Cal Poly, Team S19-G6, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G6
3 Members
60 Guides authored
6 Guide Comments
Does this fix the printer not turning on?
cindim - Reply Share
Where can I purchase the replacement Power Button? What is the part number?
Mort Rosenberg - Reply Share
Is it possible to bypass the malfunctioning power button, so the printer is on whenever it is plugged in? If so, how?
Ron Sela - Reply Share
Jack Farr
Jack Farr - Reply Share
Bonjour,
Ou peut on acheter l'écran tactile HP Officejet 4650 ???
Georges N'GUELA - Reply Share
Past 24 Hours: 2
Past 7 Days: 27
Past 30 Days: 132
All Time: 4,759
