HP OfficeJet 4650 Paper Tray Replacement
Views: 6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
110
All Time:
5,988
Comments: 6
2 comments on steps, 4 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The paper tray is what feeds paper to the printer. If the paper tray is malfunctioning, the HP OfficeJet 4650's printing function will not work. This guide will show you how to replace the paper tray.
Tools
    1. HP OfficeJet 4650 Paper Tray Replacement, Paper Tray: step 1, image 1 of 2 HP OfficeJet 4650 Paper Tray Replacement, Paper Tray: step 1, image 2 of 2
      • Use two hands to carefully flip the printer upside down.
      • Remove the ten 14mm screws by using a 2.0 mm hex screwdriver and turning the screws counterclockwise.
      Ask FixBot
    2. HP OfficeJet 4650 Paper Tray Replacement: step 2, image 1 of 2 HP OfficeJet 4650 Paper Tray Replacement: step 2, image 2 of 2
      • Lift the left and right side flaps away from the paper tray to remove them.
      Ask FixBot
    3. HP OfficeJet 4650 Paper Tray Replacement: step 3, image 1 of 3 HP OfficeJet 4650 Paper Tray Replacement: step 3, image 2 of 3 HP OfficeJet 4650 Paper Tray Replacement: step 3, image 3 of 3
      • Remove the left spring by grabbing the rubber tips connected to the spring and lifting up.
      Ask FixBot
    4. HP OfficeJet 4650 Paper Tray Replacement: step 4, image 1 of 2 HP OfficeJet 4650 Paper Tray Replacement: step 4, image 2 of 2
      • Remove the right spring by grabbing the rubber tips connected to the spring and lifting up.
      Ask FixBot
    5. HP OfficeJet 4650 Paper Tray Replacement: step 5, image 1 of 1
      • Remove the paper tray by pulling the tray away from the printer.
      Ask FixBot
Stephanie Carpintero
1,021 Reputation
5 Guides authored
Cal Poly, Team S19-G6, Livingston Winter 2018 Member of Cal Poly, Team S19-G6, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G6
3 Members
60 Guides authored
4 Guide Comments
Thank you Stephanie from a clumsy nearly 80yr old who had pulled the tray right out! A very clear guide to a simple job I had not got a clue how to do. Stay virus free and prosper. JG (UK)
John G - Reply Share
Any ideas where a aperson could order a replacement paper tray like this one? (For an HP OfficeJet 4650 model?
suemouthey - Reply Share
I broke the back of the paper tray so my printer continually says to add paper. Where can I buy another paper tray without having to buy a brand new printer?
Jacquie - Reply Share
accidentally pulled the tray out completely. guide was excellent showing me how to get it back in.
walter harrington - Reply Share
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 110
All Time: 5,988
