HP Notebook 15-ba018ds Wifi Chip Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
70
All Time:
1,454
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. HP Notebook 15-ba018ds Wifi Chip Replacement, Battery: step 1, image 1 of 1
      • Before beginning, make sure the laptop is completely turned off by pressing the off button and waiting for the screen to turn black.
      • Flip the laptop over so the battery is exposed which will be next to the hinges on the top left and right.
      Ask FixBot
    2. HP Notebook 15-ba018ds Wifi Chip Replacement: step 2, image 1 of 3 HP Notebook 15-ba018ds Wifi Chip Replacement: step 2, image 2 of 3 HP Notebook 15-ba018ds Wifi Chip Replacement: step 2, image 3 of 3
      • Place your thumbs on the slide locks that are next to the hinges and simultaneously push them toward each other to unlock the battery.
      • While still holding onto the slide locks, push the battery away from the laptop with your index fingers.
      Ask FixBot
    1. HP Notebook 15-ba018ds Wifi Chip Replacement, Wifi Chip: step 3, image 1 of 2 HP Notebook 15-ba018ds Wifi Chip Replacement, Wifi Chip: step 3, image 2 of 2
      • Unscrew the 8 screws on the back cover.
      • There are also two screws in the battery area that need to be removed.
      Ask FixBot
    2. HP Notebook 15-ba018ds Wifi Chip Replacement: step 4, image 1 of 1
      • Use an opening tool to help remove the back cover.
      • If you look at the side of the laptop, you can see where it can be separated into two parts.
      Ask FixBot
    3. HP Notebook 15-ba018ds Wifi Chip Replacement: step 5, image 1 of 2 HP Notebook 15-ba018ds Wifi Chip Replacement: step 5, image 2 of 2
      • Use a Phillips screwdriver to remove the screw holding down the wifi chip.
      Ask FixBot
    4. HP Notebook 15-ba018ds Wifi Chip Replacement: step 6, image 1 of 2 HP Notebook 15-ba018ds Wifi Chip Replacement: step 6, image 2 of 2
      • Remove the two wires connected to the wifi chip.
      • The wires are labeled 1 and 2. This is important to know when reconnecting the wires to the wifi chip.
      • Gently pull the wifi chip out and replace with a new wifi chip.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 70
All Time: 1,454
