Up to 20% off select tools
HP Notebook 15-ay087no Memory (RAM) Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
9
Past 30 Days:
45
All Time:
103
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
Hi there! This is a guide on how to change the Memory (RAM) module!
    1. HP Notebook 15-ay087no Memory (RAM) Replacement, Take out the battery: step 1, image 1 of 2 HP Notebook 15-ay087no Memory (RAM) Replacement, Take out the battery: step 1, image 2 of 2
      • Firstly we got to remove the battery to remove it we just gotta on the left side pull the tab to the right and then take it straight out by pulling back
      • Remember that on the right side it should should show an unlocked lock symbol instead of a locked one
      Ask FixBot
    2. HP Notebook 15-ay087no Memory (RAM) Replacement, Unscrewing the bottom: step 2, image 1 of 2 HP Notebook 15-ay087no Memory (RAM) Replacement, Unscrewing the bottom: step 2, image 2 of 2
      • Now we have to unscrew 10 screws Using a Philips #0 screwdriver
      • Please take off the silicone feet from the computer there are screws hidden behind them
      • It is always recommended to have some sort of map of the screws to remember where you should put them
      Ask FixBot
    3. HP Notebook 15-ay087no Memory (RAM) Replacement, Pry it open: step 3, image 1 of 1
      • Now we have to pry it up with a prying tool or a old card
      • Do NOT use a metal prying tool if you use one you will damage the computer
      Ask FixBot
    4. HP Notebook 15-ay087no Memory (RAM) Replacement, Take the backplate off: step 4, image 1 of 1
      • Now to take the backplate off we need to only grip the backplate and open it up like you're opening a laptop from the underside and then take it off entirely.
      • If it doesn't want to go off or you need to have much force double check you haven't missed some screws on the underside especially those hidden in the two silicone feet
      Ask FixBot
    5. HP Notebook 15-ay087no Memory (RAM) Replacement, Congrats: step 5, image 1 of 1
      • Congratulations! If you see the inside of the computer entirely you have done it!
      Ask FixBot
    1. HP Notebook 15-ay087no Memory (RAM) Replacement, Memory (RAM): step 6, image 1 of 2 HP Notebook 15-ay087no Memory (RAM) Replacement, Memory (RAM): step 6, image 2 of 2
      • Pull both left and right tabs and the ram module will pop up
      Ask FixBot
    2. HP Notebook 15-ay087no Memory (RAM) Replacement: step 7, image 1 of 1
      • Now the Memory module will be at an angle, take it out at that angle
      Ask FixBot
SupTheFirst
72 Reputation
9 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 45
All Time: 103
