HP Notebook 15-ay011nr Hard Drive Replacement
      • Before disassembling the computer, follow these steps:
      • Shut down the computer
      • If you are unsure whether the computer is in hibernation, turn the computer on, and then shut it down through the operating system.
      • Disconnect all external devices connected to the computer
      • Disconnect the power from the computer by first unplugging the power cord from the AC outlet and then unplugging the AC adapter from the computer
      Ask FixBot
    1. HP Notebook 15-ay011nr Hard Drive Replacement, Removing the battery: step 2, image 1 of 1
      • To remove the battery:
      • Position the computer upside down on a flat surface
      • Slide the battery lock latch (1)
      • Slide the battery release latch (2)
      • Remove the battery (3) from the computer
      Ask FixBot
    1. HP Notebook 15-ay011nr Hard Drive Replacement, Optical Drive: step 3, image 1 of 1
      • To remove the optical drive:
      • Remove the Philips PM2.5x6.0 screw (1)
      • Remove the optical drive (2) by sliding it out of the optical drive bay
      Ask FixBot
    1. HP Notebook 15-ay011nr Hard Drive Replacement, Bottom Cover: step 4, image 1 of 1
      • To remove the bottom cover:
      • Position the computer upside down the the front toward you
      • Remove the two rubber feet from the rear of the bottom of the computer (1)
      • Remove the 11 Philips PM2.5x6 screws (2) from the bottom of the computer
      • Remove the 2 Philips PM2x2 screws (3) from the optical drive bay
      Ask FixBot
    1. HP Notebook 15-ay011nr Hard Drive Replacement, Solid-state drive: step 5, image 1 of 1
      • Remove the solid-state drive
      • Remove the Philips PM2x2 screw (1) that secures the drive to the system board
      • Remove the drive (2) by pulling it away from the connector
      Ask FixBot
Alec Ringberg
653 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 67
All Time: 1,240
