Up to 20% off select tools
HP Mini 311 WWAN Card Replacement
Views: 2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
83
All Time:
1,968
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 6 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
If you are having problems with internet connection, you may want to replace your wireless network card on your HP Mini 311.
    1. HP Mini 311 WWAN Card Replacement, Battery: step 1, image 1 of 3 HP Mini 311 WWAN Card Replacement, Battery: step 1, image 2 of 3 HP Mini 311 WWAN Card Replacement, Battery: step 1, image 3 of 3
      • Lay the laptop on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
      Ask FixBot
    2. HP Mini 311 WWAN Card Replacement: step 2, image 1 of 2 HP Mini 311 WWAN Card Replacement: step 2, image 2 of 2
      • Slide the battery away from the device to remove.
      Ask FixBot
    1. HP Mini 311 WWAN Card Replacement, Memory Shield: step 3, image 1 of 1
      • With the device still in a bottom side up position, proceed to unscrew the two 4.8mm Phillips 00 screws from the memory shield.
      • The screws will remain in the shied.
      Ask FixBot
    2. HP Mini 311 WWAN Card Replacement: step 4, image 1 of 2 HP Mini 311 WWAN Card Replacement: step 4, image 2 of 2
      • Lift the memory shield up and remove from the laptop.
      Ask FixBot
    1. HP Mini 311 WWAN Card Replacement, WWAN Card: step 5, image 1 of 3 HP Mini 311 WWAN Card Replacement, WWAN Card: step 5, image 2 of 3 HP Mini 311 WWAN Card Replacement, WWAN Card: step 5, image 3 of 3
      • Begin by removing the red and blue wires from the wireless card.
      • Gently remove to avoid damaging the ends of the wires.
      Ask FixBot
    2. HP Mini 311 WWAN Card Replacement: step 6, image 1 of 1
      • Remove the two Phillips 00 3.8mm screws attached to the wireless card.
      Ask FixBot
    3. HP Mini 311 WWAN Card Replacement: step 7, image 1 of 3 HP Mini 311 WWAN Card Replacement: step 7, image 2 of 3 HP Mini 311 WWAN Card Replacement: step 7, image 3 of 3
      • Lift up the unattached side of the wireless card and pull out to remove.
      Ask FixBot
2 other people completed this guide.
Author
with
Christian Santoyo
495 Reputation
6 Guides authored
Cal Poly, Team 20-4, Maness Winter 2013 Member of Cal Poly, Team 20-4, Maness Winter 2013
CPSU-MANESS-W13S20G4
4 Members
72 Guides authored
1 Guide Comment
I don't have red and blue wires visible, are they tucked behind something? My pcie slot is vacant. What compatible part can i put here to increase speed and/or wireless connectivity?
Samant - Reply Share
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 83
All Time: 1,968
