Up to 20% off select tools
HP Mini 311 Keyboard Replacement
Views: 3.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
85
All Time:
3,292
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If you have experienced a malfunction with your keys or overall keyboard, you should change the entire keyboard on your HP Mini 311.
    1. HP Mini 311 Keyboard Replacement, Battery: step 1, image 1 of 3 HP Mini 311 Keyboard Replacement, Battery: step 1, image 2 of 3 HP Mini 311 Keyboard Replacement, Battery: step 1, image 3 of 3
      • Lay the laptop on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
      Ask FixBot
    2. HP Mini 311 Keyboard Replacement: step 2, image 1 of 2 HP Mini 311 Keyboard Replacement: step 2, image 2 of 2
      • Slide the battery away from the device to remove.
      Ask FixBot
    1. HP Mini 311 Keyboard Replacement, Memory Shield: step 3, image 1 of 1
      • With the device still in a bottom side up position, proceed to unscrew the two 4.8mm Phillips 00 screws from the memory shield.
      • The screws will remain in the shied.
      Ask FixBot
    2. HP Mini 311 Keyboard Replacement: step 4, image 1 of 2 HP Mini 311 Keyboard Replacement: step 4, image 2 of 2
      • Lift the memory shield up and remove from the laptop.
      Ask FixBot
    1. HP Mini 311 Keyboard Replacement, Hard Drive: step 5, image 1 of 3 HP Mini 311 Keyboard Replacement, Hard Drive: step 5, image 2 of 3 HP Mini 311 Keyboard Replacement, Hard Drive: step 5, image 3 of 3
      • Grab the left black, plastic tab and carefully pull upward.
      • Be sure to pull carefully. Pulling too forcefully may damage the tab.
      Ask FixBot
    2. HP Mini 311 Keyboard Replacement: step 6, image 1 of 3 HP Mini 311 Keyboard Replacement: step 6, image 2 of 3 HP Mini 311 Keyboard Replacement: step 6, image 3 of 3
      • Grab a hold of the wire connecting the hard drive and the device.
      • Pull upward, perpendicular to the surface of the laptop, releasing the connector tethering the hard drive to the motherboard.
      Ask FixBot
    1. HP Mini 311 Keyboard Replacement, Keyboard: step 7, image 1 of 1
      • Unscrew the four Phillip 00 5.6 mm screws located around the wireless card and RAM.
      Ask FixBot
    2. HP Mini 311 Keyboard Replacement: step 8, image 1 of 1
      • Open the laptop so that the screen and front of the keyboard are both facing the ground.
      • Push on the opening on the back side of the device until the keyboard partially pops out.
      • This opening is located where the original hard drive was set.
      Ask FixBot
    3. HP Mini 311 Keyboard Replacement: step 9, image 1 of 3 HP Mini 311 Keyboard Replacement: step 9, image 2 of 3 HP Mini 311 Keyboard Replacement: step 9, image 3 of 3
      • Flip the device around and orient it so that the screen and keyboard are facing you.
      • Starting at the right side, work your way towards the left end and remove the keyboard by unhinging the latches attaching it to the base of the device.
      • The right side of the keyboard should be unattached.
      • Be gentle and patient. You don't want to pull the entire keyboard at once, but rather pull by sections.
      Ask FixBot
    4. HP Mini 311 Keyboard Replacement: step 10, image 1 of 3 HP Mini 311 Keyboard Replacement: step 10, image 2 of 3 HP Mini 311 Keyboard Replacement: step 10, image 3 of 3
      • Carefully pull the ribbon cable connecting the keyboard and the laptop to remove from the device.
      Ask FixBot
4 other people completed this guide.
Author
with
Christian Santoyo
495 Reputation
6 Guides authored
Cal Poly, Team 20-4, Maness Winter 2013 Member of Cal Poly, Team 20-4, Maness Winter 2013
CPSU-MANESS-W13S20G4
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 85
All Time: 3,292
