Up to 20% off select tools
HP Mini 311 Battery Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
20
Past 30 Days:
86
All Time:
2,693
Comments: 0
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 minute
Difficulty: Very easy
Introduction
Go to step 1 ↓
If you wish to upgrade your battery life, here is how to replace the battery on your HP Mini 311.
    1. HP Mini 311 Battery Replacement, Battery: step 1, image 1 of 3 HP Mini 311 Battery Replacement, Battery: step 1, image 2 of 3 HP Mini 311 Battery Replacement, Battery: step 1, image 3 of 3
      • Lay the laptop on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
      Ask FixBot
    2. HP Mini 311 Battery Replacement: step 2, image 1 of 2 HP Mini 311 Battery Replacement: step 2, image 2 of 2
      • Slide the battery away from the device to remove.
      Ask FixBot
6 other people completed this guide.
Author
with
Christian Santoyo
495 Reputation
6 Guides authored
Cal Poly, Team 20-4, Maness Winter 2013 Member of Cal Poly, Team 20-4, Maness Winter 2013
CPSU-MANESS-W13S20G4
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 86
All Time: 2,693
