HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement
    1. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement, Battery and Service Access Cover: step 1, image 1 of 1
      • Before beginning, make sure that your computer is turned off and all external power cords are disconnected.
      • Close the laptop and turn it over so that the underside is up and the silver battery bay is facing towards you.
      Ask FixBot
    2. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: step 2, image 1 of 3 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: step 2, image 2 of 3 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: step 2, image 3 of 3
      • The battery locking latch is on the bottom right corner; slide it inward to unlock the battery.
      • Slide the battery release latch inwards.
      • Pull the battery towards you to remove it.
      Ask FixBot
    3. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: step 3, image 1 of 3 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: step 3, image 2 of 3 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: step 3, image 3 of 3
      • Slide the service access cover release lever to the right.
      • While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover.
      Ask FixBot
    4. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: step 4, image 1 of 1
      • Orient the computer as shown in the picture.
      Ask FixBot
    1. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement, Wi-Fi Card (WLAN Module): step 5, image 1 of 2 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement, Wi-Fi Card (WLAN Module): step 5, image 2 of 2
      • Locate the Wi-Fi Card (WLAN Module), near the computer's bottom left corner.
      Ask FixBot
    2. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: step 6, image 1 of 3 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: step 6, image 2 of 3 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: step 6, image 3 of 3
      • Disconnect the two cables from the Wi-Fi card by gently lifting them away from the card.
      • There should be two black cables, one labeled with a white sticker, connected to the module.
      Ask FixBot
    3. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: step 7, image 1 of 1
      • Remove the two 2.0 x 3.0 screws securing the Wi-Fi card using a Phillips #00 screwdriver
      • The card should tilt up away from the laptop at an angle after removing the screws.
      Ask FixBot
    4. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: step 8, image 1 of 1
      • Remove the Wi-Fi card by gently pulling it out of its slot at an angle.
      • Potential for device damage: Be sure to pull gently and at an angle away from you. If the card is pulled straight up, there is a chance it could break or bend.
      Ask FixBot
Taylor
116 Reputation
1 Guide authored
Cal Poly, Team 3-23, Amido Fall 2012 Member of Cal Poly, Team 3-23, Amido Fall 2012
CPSU-AMIDO-F12S3G23
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 29
All Time: 1,612
