Up to 20% off select tools
HP Mini 210-2070NR RAM Replacement
Views: 2.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
91
All Time:
2,799
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Parts
Introduction
Go to step 1 ↓
Use this guide to replace your RAM Card. Replacing your RAM card for one of higher capacity will allow your system to perform better.
    1. HP Mini 210-2070NR RAM Replacement, Battery and Service Access Cover: step 1, image 1 of 1
      • Before beginning, make sure that your computer is turned off and all external power cords are disconnected.
      • Close the laptop and turn it over so that the underside is up and the silver battery bay is facing towards you.
      Ask FixBot
    2. HP Mini 210-2070NR RAM Replacement: step 2, image 1 of 3 HP Mini 210-2070NR RAM Replacement: step 2, image 2 of 3 HP Mini 210-2070NR RAM Replacement: step 2, image 3 of 3
      • The battery locking latch is on the bottom right corner; slide it inward to unlock the battery.
      • Slide the battery release latch inwards.
      • Pull the battery towards you to remove it.
      Ask FixBot
    3. HP Mini 210-2070NR RAM Replacement: step 3, image 1 of 3 HP Mini 210-2070NR RAM Replacement: step 3, image 2 of 3 HP Mini 210-2070NR RAM Replacement: step 3, image 3 of 3
      • Slide the service access cover release lever to the right.
      • While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover.
      Ask FixBot
    4. HP Mini 210-2070NR RAM Replacement: step 4, image 1 of 1
      • Orient the computer as shown in the picture.
      Ask FixBot
    1. HP Mini 210-2070NR RAM Replacement, RAM: step 5, image 1 of 1
      • Using your fingers, pull the two white clips (tabs) on both sides of the RAM away from each other. Keep pulling the clips until the RAM pops up
      • Hold the RAM on the edges only. Touching the components on the RAM might damage it.
      Ask FixBot
    2. HP Mini 210-2070NR RAM Replacement: step 6, image 1 of 1
      • Grab the edges of the module and gently lift it from the slot.
      • RAM Cards are designed with a notch on the surface to prevent incorrect insertion into the memory module slot.
      Ask FixBot
2 other people completed this guide.
Author
with
Sean Kuster
91 Reputation
3 Guides authored
Cal Poly, Team 3-23, Amido Fall 2012 Member of Cal Poly, Team 3-23, Amido Fall 2012
CPSU-AMIDO-F12S3G23
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 91
All Time: 2,799
