HP Mini 210 WiFi Card Replacement
Views: 6.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
101
All Time:
6,206
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 8
8 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Missing Steps
Oops! This guide is currently missing one or more important steps.
Introduction
Go to step 1 ↓
Installing a new WiFi card is quick and simple.
The WiFi card in the HP Mini 210 uses a Mini PCIe interface, which is the de-facto standard on recent laptops. Please ensure you install an official HP verified wireless card to prevent running into errors.
Tools
    1. HP Mini 210 WiFi Card Replacement, Battery: step 1, image 1 of 2 HP Mini 210 WiFi Card Replacement, Battery: step 1, image 2 of 2
      • Turn off and unplug the netbook before replacing the battery.
      • Hold the netbook top-side down with the lid closed.
      • Slide the plastic battery release latches towards the lock symbols.
      • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
      Ask FixBot
    2. HP Mini 210 WiFi Card Replacement: step 2, image 1 of 1
      • Slide the battery out from the netbook.
      Ask FixBot
    1. HP Mini 210 WiFi Card Replacement, Disassembling HP Mini 210 Back Case: step 3, image 1 of 1
      • Turn the netbook to view its edge.
      • Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
      Ask FixBot
    2. HP Mini 210 WiFi Card Replacement: step 4, image 1 of 1
      • If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
      Ask FixBot
    3. HP Mini 210 WiFi Card Replacement: step 5, image 1 of 1
      • Pull the back case off from the front edge.
      Ask FixBot
    1. HP Mini 210 WiFi Card Replacement, WiFi Card: step 6, image 1 of 1
      • Pop out the two gold connectors from the antenna wires on top of the WiFi card using a plastic opening tool. This will allow you to dislodge the WiFi card from the rest of the netbook.
      Ask FixBot
    2. HP Mini 210 WiFi Card Replacement: step 7, image 1 of 1
      • Remove the two 3.9 mm screws on top of the WiFi card using the Phillips #00 screwdriver.
      Ask FixBot
    3. HP Mini 210 WiFi Card Replacement: step 8, image 1 of 1
      • Gently pull the WiFi card out of its slot. Be sure to pull the card up and out of the slot towards you.
      Ask FixBot
Heather Freed
723 Reputation
8 Guides authored
Cal Poly, Team 9-17, Amido Fall 2012 Member of Cal Poly, Team 9-17, Amido Fall 2012
CPSU-AMIDO-F12S9G17
3 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 101
All Time: 6,206
