Up to 20% off select tools
HP Mini 210 RAM Replacement
Views: 8.7K
View statistics:
Past 24 Hours:
5
Past 7 Days:
22
Past 30 Days:
124
All Time:
8,732
Comments: 1
1 guide comment.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 6
6 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Missing Steps
Oops! This guide is currently missing one or more important steps.
Parts
Tools
  • Spudger
    4.9
Introduction
Go to step 1 ↓
Installing new RAM (random access memory) on your netbook is quick and requires little disassembly.
    1. HP Mini 210 RAM Replacement, Battery: step 1, image 1 of 2 HP Mini 210 RAM Replacement, Battery: step 1, image 2 of 2
      • Turn off and unplug the netbook before replacing the battery.
      • Hold the netbook top-side down with the lid closed.
      • Slide the plastic battery release latches towards the lock symbols.
      • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
      Ask FixBot
    2. HP Mini 210 RAM Replacement: step 2, image 1 of 1
      • Slide the battery out from the netbook.
      Ask FixBot
    1. HP Mini 210 RAM Replacement, Disassembling HP Mini 210 Back Case: step 3, image 1 of 1
      • Turn the netbook to view its edge.
      • Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
      Ask FixBot
    2. HP Mini 210 RAM Replacement: step 4, image 1 of 1
      • If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
      Ask FixBot
    3. HP Mini 210 RAM Replacement: step 5, image 1 of 1
      • Pull the back case off from the front edge.
      Ask FixBot
    1. HP Mini 210 RAM Replacement, RAM: step 6, image 1 of 1
      • Push out the two plastic prongs on either side of the RAM.
      Ask FixBot
    2. HP Mini 210 RAM Replacement: step 7, image 1 of 1
      • The RAM should pop up allowing for easy removal from its compartment.
      • Pull out the RAM.
      Ask FixBot
7 other people completed this guide.
Author
with
Heather Freed
723 Reputation
8 Guides authored
Cal Poly, Team 9-17, Amido Fall 2012 Member of Cal Poly, Team 9-17, Amido Fall 2012
CPSU-AMIDO-F12S9G17
3 Members
96 Guides authored
1 Guide Comment
Thanks. The back case is a bit tricky to unclip; also took a bit of work to reassemble the case back on.
Max99 - Reply Share
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 124
All Time: 8,732
