Up to 20% off select tools
HP Mini 210 Keyboard Replacement
Views: 16K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
101
All Time:
16,073
Comments: 0
Go to guide comments
Completed: 11
11 people have marked this guide "completed." Will you be next?
Favorites: 11
11 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 20 minutes
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
Introduction
Go to step 1 ↓
This guide will show you how to install a keyboard from the backside of the netbook. You want to replace your keyboard if you are experiencing any keyboard malfunctions, such as a slow or non-existent response from the keyboard to the computer. The keyboard does not require too much disassembly of the laptop, and it should take no time at all to repair.
    1. HP Mini 210 Keyboard Replacement, Battery: step 1, image 1 of 2 HP Mini 210 Keyboard Replacement, Battery: step 1, image 2 of 2
      • Turn off and unplug the netbook before replacing the battery.
      • Hold the netbook top-side down with the lid closed.
      • Slide the plastic battery release latches towards the lock symbols.
      • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
      Ask FixBot
    2. HP Mini 210 Keyboard Replacement: step 2, image 1 of 1
      • Slide the battery out from the netbook.
      Ask FixBot
    1. HP Mini 210 Keyboard Replacement, Disassembling HP Mini 210 Back Case: step 3, image 1 of 1
      • Turn the netbook to view its edge.
      • Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
      Ask FixBot
    2. HP Mini 210 Keyboard Replacement: step 4, image 1 of 1
      • If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
      Ask FixBot
    3. HP Mini 210 Keyboard Replacement: step 5, image 1 of 1
      • Pull the back case off from the front edge.
      Ask FixBot
    1. HP Mini 210 Keyboard Replacement, Keyboard: step 6, image 1 of 3 HP Mini 210 Keyboard Replacement, Keyboard: step 6, image 2 of 3 HP Mini 210 Keyboard Replacement, Keyboard: step 6, image 3 of 3
      • Using a screwdriver, remove the three 6.6 mm screws highlighted with the red circles in the first picture above.
      Ask FixBot
    2. HP Mini 210 Keyboard Replacement: step 7, image 1 of 2 HP Mini 210 Keyboard Replacement: step 7, image 2 of 2
      • Once you have removed the screws, flip the netbook over so that the keyboard is now facing upwards. Open the screen as far back as the netbook allows.
      • Using a prying tool, lift upwards and remove the plastic casing that covers the spaces around the keys of the keyboard.
      • Be careful when removing the plastic casing.
      Ask FixBot
    3. HP Mini 210 Keyboard Replacement: step 8, image 1 of 3 HP Mini 210 Keyboard Replacement: step 8, image 2 of 3 HP Mini 210 Keyboard Replacement: step 8, image 3 of 3
      • After removing the plastic casing surrounding the keys, carefully lift the full keyboard from the netbook using a plastic opening tool.
      • Do not yank the keyboard out. The keyboard is attached to the netbook through a ribbon cable, which needs to remain undamaged in order for the new keyboard to properly connect with the netbook.
      Ask FixBot
    4. HP Mini 210 Keyboard Replacement: step 9, image 1 of 3 HP Mini 210 Keyboard Replacement: step 9, image 2 of 3 HP Mini 210 Keyboard Replacement: step 9, image 3 of 3
      • Be very gentle with the ZIF connector! It is designed to be locked into the motherboard, so make sure you lift the retaining latch before attempting to disconnect it.
      • Lift the latch on the ZIF (zero insertion-force) connector using a plastic opening tool. The ZIF connector is located on the motherboard and is connected to the keyboard through the ribbon cable.
      • Disconnect the ribbon cable from the ZIF connector on the motherboard by lifting it up and out; this completely removes the keyboard.
      Ask FixBot
11 other people completed this guide.
Author
with
Heather Freed
723 Reputation
8 Guides authored
Cal Poly, Team 9-17, Amido Fall 2012 Member of Cal Poly, Team 9-17, Amido Fall 2012
CPSU-AMIDO-F12S9G17
3 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 101
All Time: 16,073
