Up to 20% off select tools
HP Mini 210 Hard Drive Replacement
Views: 20K
View statistics:
Past 24 Hours:
4
Past 7 Days:
26
Past 30 Days:
119
All Time:
19,688
Comments: 1
1 guide comment.
Go to guide comments
Completed: 14
14 people have marked this guide "completed." Will you be next?
Favorites: 6
6 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 20 minutes
Difficulty: Easy
Missing Steps
Oops! This guide is currently missing one or more important steps.
Tools
  • Spudger
    4.9
  • Tweezers
    (optional)
  • iFixit Opening Tool
    4.8
Introduction
Go to step 1 ↓
If the hard drive makes scratching or whining noises, or if the operating system does not boot due to a disk read error, you may need to replace it.
The hard drive contains operating system files and your personal files. If you intend to replace the hard drive, save any personal files you need later onto an alternative media source before completing these steps. You will need to install an operating system on the new hard drive once the new hard drive is installed on the netbook.
    1. HP Mini 210 Hard Drive Replacement, Battery: step 1, image 1 of 2 HP Mini 210 Hard Drive Replacement, Battery: step 1, image 2 of 2
      • Turn off and unplug the netbook before replacing the battery.
      • Hold the netbook top-side down with the lid closed.
      • Slide the plastic battery release latches towards the lock symbols.
      • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
      Ask FixBot
    2. HP Mini 210 Hard Drive Replacement: step 2, image 1 of 1
      • Slide the battery out from the netbook.
      Ask FixBot
    1. HP Mini 210 Hard Drive Replacement, Disassembling HP Mini 210 Back Case: step 3, image 1 of 1
      • Turn the netbook to view its edge.
      • Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
      Ask FixBot
    2. HP Mini 210 Hard Drive Replacement: step 4, image 1 of 1
      • If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
      Ask FixBot
    3. HP Mini 210 Hard Drive Replacement: step 5, image 1 of 1
      • Pull the back case off from the front edge.
      Ask FixBot
    1. HP Mini 210 Hard Drive Replacement, Hard Drive: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Peel back the black sticker covering the hard drive with tweezers or your fingers.
      Ask FixBot
    2. HP Mini 210 Hard Drive Replacement: step 7, image 1 of 1
      • Use a plastic opening tool to carefully disconnect the hard drive connector found above the RAM slot.
      Ask FixBot
    3. HP Mini 210 Hard Drive Replacement: step 8, image 1 of 2 HP Mini 210 Hard Drive Replacement: step 8, image 2 of 2
      • Pull the silver plastic tab up and remove the hard drive. The tab may also be black.
      • Be aware of the 4 foam cushions on each corner of the hard drive as they may become loose during removal.
      Ask FixBot
14 other people completed this guide.
Author
with
Heather Freed
723 Reputation
8 Guides authored
Cal Poly, Team 9-17, Amido Fall 2012 Member of Cal Poly, Team 9-17, Amido Fall 2012
CPSU-AMIDO-F12S9G17
3 Members
96 Guides authored
1 Guide Comment
Be aware that some models don't have buttons but a orange switch that need some pressure to release the cover
Alejandro - Reply Share
Past 24 Hours: 4
Past 7 Days: 26
Past 30 Days: 119
All Time: 19,688
