Up to 20% off select tools
HP Mini 210 CMOS Battery Replacement
Views: 18K
View statistics:
Past 24 Hours:
5
Past 7 Days:
40
Past 30 Days:
177
All Time:
17,661
Comments: 2
2 guide comments.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 8
8 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Easy
Missing Steps
Oops! This guide is currently missing one or more important steps.
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
Introduction
Go to step 1 ↓
If the system clock or the BIOS (Basic Input/Output System) settings reset when the netbook is turned off, the CMOS (Complementary Metal-Oxide Semiconductor) battery may need to be replaced.
The CMOS battery should be replaced with a 3-volt 2032-size coin battery.
    1. HP Mini 210 CMOS Battery Replacement, Battery: step 1, image 1 of 2 HP Mini 210 CMOS Battery Replacement, Battery: step 1, image 2 of 2
      • Turn off and unplug the netbook before replacing the battery.
      • Hold the netbook top-side down with the lid closed.
      • Slide the plastic battery release latches towards the lock symbols.
      • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
      Ask FixBot
    2. HP Mini 210 CMOS Battery Replacement: step 2, image 1 of 1
      • Slide the battery out from the netbook.
      Ask FixBot
    1. HP Mini 210 CMOS Battery Replacement, Disassembling HP Mini 210 Back Case: step 3, image 1 of 1
      • Turn the netbook to view its edge.
      • Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
      Ask FixBot
    2. HP Mini 210 CMOS Battery Replacement: step 4, image 1 of 1
      • If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
      Ask FixBot
    3. HP Mini 210 CMOS Battery Replacement: step 5, image 1 of 1
      • Pull the back case off from the front edge.
      Ask FixBot
    1. HP Mini 210 CMOS Battery Replacement, CMOS Battery: step 6, image 1 of 1
      • Cut one side of the black adhesive ribbon on top of the CMOS battery with a utility blade.
      • Be careful not to scratch or damage the battery or netbook, and be sure to keep your fingers out of the way!
      Ask FixBot
    2. HP Mini 210 CMOS Battery Replacement: step 7, image 1 of 1
      Tool used on this step:
      Buy
      • Slowly peel back the black adhesive ribbon with tweezers.
      Ask FixBot
    3. HP Mini 210 CMOS Battery Replacement: step 8, image 1 of 1
      • Pry the CMOS battery out with a plastic opening tool.
      Ask FixBot
    4. HP Mini 210 CMOS Battery Replacement: step 9, image 1 of 1
      • Pop the CMOS battery out.
      • When reinstalling, insert the battery back into the slot with the positive terminal facing up.
      Ask FixBot
8 other people completed this guide.
Author
with
Heather Freed
723 Reputation
8 Guides authored
Cal Poly, Team 9-17, Amido Fall 2012 Member of Cal Poly, Team 9-17, Amido Fall 2012
CPSU-AMIDO-F12S9G17
3 Members
96 Guides authored
2 Guide Comments
after need CMOS reset. Screen is black. Is there an easy way on my HP Mini 210?
Carl Louviere - Reply Share
Very good tut. Now my HP Mini 210 can get the right time xD
Byte Core - Reply Share
Past 24 Hours: 5
Past 7 Days: 40
Past 30 Days: 177
All Time: 17,661
