Up to 20% off select tools
HP Mini 210 Battery Replacement
Views: 7.1K
View statistics:
Past 24 Hours:
6
Past 7 Days:
23
Past 30 Days:
117
All Time:
7,133
Comments: 1
1 guide comment.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 minute
Difficulty: Very easy
Missing Steps
Oops! This guide is currently missing one or more important steps.
Introduction
Go to step 1 ↓
Replacing the battery in this netbook is quick and does not require any disassembly.
    1. HP Mini 210 Battery Replacement, Battery: step 1, image 1 of 2 HP Mini 210 Battery Replacement, Battery: step 1, image 2 of 2
      • Turn off and unplug the netbook before replacing the battery.
      • Hold the netbook top-side down with the lid closed.
      • Slide the plastic battery release latches towards the lock symbols.
      • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
      Ask FixBot
    2. HP Mini 210 Battery Replacement: step 2, image 1 of 1
      • Slide the battery out from the netbook.
      Ask FixBot
6 other people completed this guide.
Author
with
Heather Freed
723 Reputation
8 Guides authored
Cal Poly, Team 9-17, Amido Fall 2012 Member of Cal Poly, Team 9-17, Amido Fall 2012
CPSU-AMIDO-F12S9G17
3 Members
96 Guides authored
1 Guide Comment
How do I put put the battery back though?
Riku 97 - Reply Share
Past 24 Hours: 6
Past 7 Days: 23
Past 30 Days: 117
All Time: 7,133
