HP Mini 110-3735dx Screen Replacement
    1. HP Mini 110-3735dx Screen Replacement, Battery: step 1, image 1 of 3 HP Mini 110-3735dx Screen Replacement, Battery: step 1, image 2 of 3 HP Mini 110-3735dx Screen Replacement, Battery: step 1, image 3 of 3
      • With the bottom of the HP Mini facing up, slide both switches inward towards each other.
      Ask FixBot
    2. HP Mini 110-3735dx Screen Replacement: step 2, image 1 of 2 HP Mini 110-3735dx Screen Replacement: step 2, image 2 of 2
      • With the left switch still pushed inward, pull the battery towards you to remove it from the computer.
      Ask FixBot
    1. HP Mini 110-3735dx Screen Replacement, Backcover: step 3, image 1 of 3 HP Mini 110-3735dx Screen Replacement, Backcover: step 3, image 2 of 3 HP Mini 110-3735dx Screen Replacement, Backcover: step 3, image 3 of 3
      • Pull upward from under the back cover via the missing battery area.
      • Best to start from one of the corners.
      Ask FixBot
    1. HP Mini 110-3735dx Screen Replacement, Keyboard: step 4, image 1 of 2 HP Mini 110-3735dx Screen Replacement, Keyboard: step 4, image 2 of 2
      • Remove the three 4.0 mm screws with the keyboard indicator next to them using a Phillips #1 screw driver.
      Ask FixBot
    2. HP Mini 110-3735dx Screen Replacement: step 5, image 1 of 2 HP Mini 110-3735dx Screen Replacement: step 5, image 2 of 2
      • Flip the laptop over, and open it up.
      • Don't worry! No pieces will fall out.
      Ask FixBot
    3. HP Mini 110-3735dx Screen Replacement: step 6, image 1 of 2 HP Mini 110-3735dx Screen Replacement: step 6, image 2 of 2
      • With the keyboard facing you, pull the black bezel upward until its loose.
      • You should hear three clicks.
      Ask FixBot
    4. HP Mini 110-3735dx Screen Replacement: step 7, image 1 of 2 HP Mini 110-3735dx Screen Replacement: step 7, image 2 of 2
      • Move and hold the bezel slightly towards the screen while lifting the keyboard from the top.
      Ask FixBot
    5. HP Mini 110-3735dx Screen Replacement: step 8, image 1 of 1
      • Pull up the keyboard from the bottom corners exposing the keyboard cable.
      Ask FixBot
    6. HP Mini 110-3735dx Screen Replacement: step 9, image 1 of 2 HP Mini 110-3735dx Screen Replacement: step 9, image 2 of 2
      • Lift the black holder connected to the keyboard cable until it points up.
      Ask FixBot
    7. HP Mini 110-3735dx Screen Replacement: step 10, image 1 of 2 HP Mini 110-3735dx Screen Replacement: step 10, image 2 of 2
      • Gently pull the keyboard cable from the socket.
      Ask FixBot
    1. HP Mini 110-3735dx Screen Replacement, Hard Drive Cage: step 11, image 1 of 1
      • Remove the three 5.0 mm screws holding the hard drive cage in place using a Phillips #1 screw driver.
      Ask FixBot
    2. HP Mini 110-3735dx Screen Replacement: step 12, image 1 of 3 HP Mini 110-3735dx Screen Replacement: step 12, image 2 of 3 HP Mini 110-3735dx Screen Replacement: step 12, image 3 of 3
      • Lift the hard drive cage by pulling the tape upward.
      • Start by pulling the tape from the side with the keyboard symbol.
      Ask FixBot
    3. HP Mini 110-3735dx Screen Replacement: step 13, image 1 of 2 HP Mini 110-3735dx Screen Replacement: step 13, image 2 of 2
      • Unplug the cable connecting to the hard drive.
      Ask FixBot
    1. HP Mini 110-3735dx Screen Replacement, Screen: step 14, image 1 of 2 HP Mini 110-3735dx Screen Replacement, Screen: step 14, image 2 of 2
      • Remove the 8 5.0 mm screws under the keyboard using a Phillips #1 screw driver.
      Ask FixBot
    2. HP Mini 110-3735dx Screen Replacement: step 15, image 1 of 3 HP Mini 110-3735dx Screen Replacement: step 15, image 2 of 3 HP Mini 110-3735dx Screen Replacement: step 15, image 3 of 3
      • Lift the two black holders upward located next to the socket for the keyboard close to the tracked pad.
      Ask FixBot
    3. HP Mini 110-3735dx Screen Replacement: step 16, image 1 of 2 HP Mini 110-3735dx Screen Replacement: step 16, image 2 of 2
      • Remove the two connectors for the motherboard from their sockets.
      Ask FixBot
    4. HP Mini 110-3735dx Screen Replacement: step 17, image 1 of 2 HP Mini 110-3735dx Screen Replacement: step 17, image 2 of 2
      • Close the laptop by bringing the screen down.
      • Flip the laptop over to the other side.
      Ask FixBot
    5. HP Mini 110-3735dx Screen Replacement: step 18, image 1 of 2 HP Mini 110-3735dx Screen Replacement: step 18, image 2 of 2
      • Remove the 6 5.0 mm screws holding the back plate together using a Phillips #1 screw driver.
      Ask FixBot
    6. HP Mini 110-3735dx Screen Replacement: step 19, image 1 of 2 HP Mini 110-3735dx Screen Replacement: step 19, image 2 of 2
      • Remove the 2 3.0 mm screw head holding the plastic piece in place using a Phillips #1 screw driver.
      • Located on the left and right side where the battery was removed.
      Ask FixBot
    7. HP Mini 110-3735dx Screen Replacement: step 20, image 1 of 3 HP Mini 110-3735dx Screen Replacement: step 20, image 2 of 3 HP Mini 110-3735dx Screen Replacement: step 20, image 3 of 3
      • Pull the black plastic pieces that the screws was holding inward.
      • The pieces are located on the left and right corners connecting the bottom and top of the HP Mini.
      Ask FixBot
    8. HP Mini 110-3735dx Screen Replacement: step 21, image 1 of 2 HP Mini 110-3735dx Screen Replacement: step 21, image 2 of 2
      • Flip the laptop back over.
      • Open it by lifting the screeen.
      Ask FixBot
    9. HP Mini 110-3735dx Screen Replacement: step 22, image 1 of 3 HP Mini 110-3735dx Screen Replacement: step 22, image 2 of 3 HP Mini 110-3735dx Screen Replacement: step 22, image 3 of 3
      • Right next to the previous plastic piece, remove the other two plastic pieces.
      • This may be difficult to come off. Tilt the screen back and forth to help loosen the piece.
      Ask FixBot
    10. HP Mini 110-3735dx Screen Replacement: step 23, image 1 of 1
      • Using the plastic prying tool, pry the front plate of the bottom part of your HP Mini.
      • Start along the speaker grill near the touch pad, and move along the sides.
      Ask FixBot
    11. HP Mini 110-3735dx Screen Replacement: step 24, image 1 of 2 HP Mini 110-3735dx Screen Replacement: step 24, image 2 of 2
      • Lift up the front plate where the keyboard was.
      Ask FixBot
    12. HP Mini 110-3735dx Screen Replacement: step 25, image 1 of 3 HP Mini 110-3735dx Screen Replacement: step 25, image 2 of 3 HP Mini 110-3735dx Screen Replacement: step 25, image 3 of 3
      • Remove the display cable from the motherboard located on the top left corner under where the keyboard was by pulling on the black tab.
      • Move the cable.
      Ask FixBot
    13. HP Mini 110-3735dx Screen Replacement: step 26, image 1 of 3 HP Mini 110-3735dx Screen Replacement: step 26, image 2 of 3 HP Mini 110-3735dx Screen Replacement: step 26, image 3 of 3
      • Remove the webcam cables from the motherboard.
      • Located on the back side of the laptop in the bottom left corner.
      Ask FixBot
    14. HP Mini 110-3735dx Screen Replacement: step 27, image 1 of 1
      • Flip over the computer, and open the laptop.
      • Lift up the front plate on the top right corner.
      Ask FixBot
    15. HP Mini 110-3735dx Screen Replacement: step 28, image 1 of 3 HP Mini 110-3735dx Screen Replacement: step 28, image 2 of 3 HP Mini 110-3735dx Screen Replacement: step 28, image 3 of 3
      Tool used on this step:
      Buy
      • Pull the cables for the web cam out using tweezers.
      Ask FixBot
    16. HP Mini 110-3735dx Screen Replacement: step 29, image 1 of 2 HP Mini 110-3735dx Screen Replacement: step 29, image 2 of 2
      • Remove the 2 3.0 mm screws on both sides of the bottom of the display using a Phillips #1 screwdriver.
      Ask FixBot
    17. HP Mini 110-3735dx Screen Replacement: step 30, image 1 of 2 HP Mini 110-3735dx Screen Replacement: step 30, image 2 of 2
      • Remove the black plastic piece that the screw was holding on both sides.
      • This will reveal another screw.
      Ask FixBot
    18. HP Mini 110-3735dx Screen Replacement: step 31, image 1 of 2 HP Mini 110-3735dx Screen Replacement: step 31, image 2 of 2
      • Remove the 2 3.0 mm screws on both sides using a Phillips #1 screw driver.
      • When removing, keep hold of the screen to make sure it doesn't fall.
      Ask FixBot
    19. HP Mini 110-3735dx Screen Replacement: step 32, image 1 of 1
      • Pry the front plate using the plastic opening tool by pushing along the border of the front and back plate.
      • Make sure to pry from the sides, top and bottom as the corners will come undone themselves.
      Ask FixBot
    20. HP Mini 110-3735dx Screen Replacement: step 33, image 1 of 3 HP Mini 110-3735dx Screen Replacement: step 33, image 2 of 3 HP Mini 110-3735dx Screen Replacement: step 33, image 3 of 3
      • Remove the front plate.
      • Pull the cables through the holes.
      Ask FixBot
    21. HP Mini 110-3735dx Screen Replacement: step 34, image 1 of 2 HP Mini 110-3735dx Screen Replacement: step 34, image 2 of 2
      • Remove the 4 4.0 mm screws holding the screen in place using a Phillips #1 screw driver.
      Ask FixBot
    22. HP Mini 110-3735dx Screen Replacement: step 35, image 1 of 2 HP Mini 110-3735dx Screen Replacement: step 35, image 2 of 2
      • Lift the screen up.
      Ask FixBot
    23. HP Mini 110-3735dx Screen Replacement: step 36, image 1 of 2 HP Mini 110-3735dx Screen Replacement: step 36, image 2 of 2
      • Under the screen, peel off the tape near the cable completely, so you can see the socket for the cable.
      Ask FixBot
Tyrone Williams
923 Reputation
7 Guides authored
1 Guide Comment
Tengo una pregunta en pantalla habrá alguna otra que sea compatible con esta hp sin ser el mismo modelo?
Icela Ross - Reply Share
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 93
All Time: 1,332
