Up to 20% off select tools
HP Mini 110-3735dx RAM Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
5
Past 7 Days:
22
Past 30 Days:
95
All Time:
1,548
Comments: 1
1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 4 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If your computer is running slow, has had blue screen of death, or you want to upgrade your HP Mini, follow this guide for replacing your RAM.
    1. HP Mini 110-3735dx RAM Replacement, Battery: step 1, image 1 of 3 HP Mini 110-3735dx RAM Replacement, Battery: step 1, image 2 of 3 HP Mini 110-3735dx RAM Replacement, Battery: step 1, image 3 of 3
      • With the bottom of the HP Mini facing up, slide both switches inward towards each other.
      Ask FixBot
    2. HP Mini 110-3735dx RAM Replacement: step 2, image 1 of 2 HP Mini 110-3735dx RAM Replacement: step 2, image 2 of 2
      • With the left switch still pushed inward, pull the battery towards you to remove it from the computer.
      Ask FixBot
    1. HP Mini 110-3735dx RAM Replacement, Backcover: step 3, image 1 of 3 HP Mini 110-3735dx RAM Replacement, Backcover: step 3, image 2 of 3 HP Mini 110-3735dx RAM Replacement, Backcover: step 3, image 3 of 3
      • Pull upward from under the back cover via the missing battery area.
      • Best to start from one of the corners.
      Ask FixBot
    1. HP Mini 110-3735dx RAM Replacement, RAM: step 4, image 1 of 2 HP Mini 110-3735dx RAM Replacement, RAM: step 4, image 2 of 2
      • Push the two white holders holding the RAM outward until it points upwards at about a 45 degree angle.
      Ask FixBot
    2. HP Mini 110-3735dx RAM Replacement: step 5, image 1 of 2 HP Mini 110-3735dx RAM Replacement: step 5, image 2 of 2
      • Gently pull the RAM from it's socket.
      Ask FixBot
3 other people completed this guide.
Author
with
Tyrone Williams
923 Reputation
7 Guides authored
1 Guide Comment
Thank you! It was easy!
zeppo1207 - Reply Share
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 95
All Time: 1,548
