Introduction
If your hard drive is broken or you just want to upgrade, this guide will walk you through the steps for replacing the hard drive.
With the bottom of the HP Mini facing up, slide both switches inward towards each other.
Remove the three 5.0 mm screws holding the hard drive cage in place using a Phillips #1 screw driver.
Remove the four 4.0 mm screws on both sides of the cage using a Phillips #1 screw driver.
2 other people completed this guide.
