HP Mini 110-3735dx Hard Drive Cage Replacement
    1. HP Mini 110-3735dx Hard Drive Cage Replacement, Battery: step 1, image 1 of 3 HP Mini 110-3735dx Hard Drive Cage Replacement, Battery: step 1, image 2 of 3 HP Mini 110-3735dx Hard Drive Cage Replacement, Battery: step 1, image 3 of 3
      • With the bottom of the HP Mini facing up, slide both switches inward towards each other.
      Ask FixBot
    2. HP Mini 110-3735dx Hard Drive Cage Replacement: step 2, image 1 of 2 HP Mini 110-3735dx Hard Drive Cage Replacement: step 2, image 2 of 2
      • With the left switch still pushed inward, pull the battery towards you to remove it from the computer.
      Ask FixBot
    1. HP Mini 110-3735dx Hard Drive Cage Replacement, Backcover: step 3, image 1 of 3 HP Mini 110-3735dx Hard Drive Cage Replacement, Backcover: step 3, image 2 of 3 HP Mini 110-3735dx Hard Drive Cage Replacement, Backcover: step 3, image 3 of 3
      • Pull upward from under the back cover via the missing battery area.
      • Best to start from one of the corners.
      Ask FixBot
    1. HP Mini 110-3735dx Hard Drive Cage Replacement, Hard Drive Cage: step 4, image 1 of 1
      • Remove the three 5.0 mm screws holding the hard drive cage in place using a Phillips #1 screw driver.
      Ask FixBot
    2. HP Mini 110-3735dx Hard Drive Cage Replacement: step 5, image 1 of 3 HP Mini 110-3735dx Hard Drive Cage Replacement: step 5, image 2 of 3 HP Mini 110-3735dx Hard Drive Cage Replacement: step 5, image 3 of 3
      • Lift the hard drive cage by pulling the tape upward.
      • Start by pulling the tape from the side with the keyboard symbol.
      Ask FixBot
    3. HP Mini 110-3735dx Hard Drive Cage Replacement: step 6, image 1 of 2 HP Mini 110-3735dx Hard Drive Cage Replacement: step 6, image 2 of 2
      • Unplug the cable connecting to the hard drive.
      Ask FixBot
Tyrone Williams
923 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 22
All Time: 549
