HP Mini 110-3131dx Touchpad Replacement
      • Power off the laptop before trying to remove the battery.
      • Turn the laptop upside down, and locate the sliding tabs on the battery.
      • Slide both tabs in an inward direction, then slide the battery away from the laptop.
      Ask FixBot
    1. HP Mini 110-3131dx Touchpad Replacement, Keyboard: step 2, image 1 of 1
      • Remove the three black screws marked by the keyboard symbol using a Phillips #1 screwdriver.
      Ask FixBot
    2. HP Mini 110-3131dx Touchpad Replacement: step 3, image 1 of 3 HP Mini 110-3131dx Touchpad Replacement: step 3, image 2 of 3 HP Mini 110-3131dx Touchpad Replacement: step 3, image 3 of 3
      • Turn the laptop upright and open it.
      • Disconnect the clips located around the perimeter of the keyboard.
      • Slide the iFixit opening tool between the top edge of the keyboard and the plastic bezel.
      • Start either above the esc key or the delete key.
      • Pull the keyboard with your fingers until it comes out on both sides.
      • Be careful not to pull the keyboard out too fast. There is a fragile ribbon cable that attaches to the motherboard behind the keyboard.
      Ask FixBot
    3. HP Mini 110-3131dx Touchpad Replacement: step 4, image 1 of 1
      • Tilt the keyboard toward you to reveal the ribbon cable.
      • Lift up the black tab on top of the keyboard ribbon cable to release the ribbon cable.
      • Pull the ribbon cable out of its container.
      Ask FixBot
    1. HP Mini 110-3131dx Touchpad Replacement, Keyboard Bezel: step 5, image 1 of 2 HP Mini 110-3131dx Touchpad Replacement, Keyboard Bezel: step 5, image 2 of 2
      • Remove the six black screws around the perimeter of the laptop using a Phillips #1 screwdriver.
      • Be sure to keep track of which screws go where as they are not all the same size.
      • Flip the laptop over and remove the six black screws.
      Ask FixBot
    2. HP Mini 110-3131dx Touchpad Replacement: step 6, image 1 of 2 HP Mini 110-3131dx Touchpad Replacement: step 6, image 2 of 2
      • Using your fingernail or the iFixit opening tool, flip the black tab up to release the ribbon cable that connects the touchpad and motherboard.
      • Disconnect the red and black wires from the motherboard on the left-hand side of the bezel using your fingernail or iFixit opening tool.
      Ask FixBot
    3. HP Mini 110-3131dx Touchpad Replacement: step 7, image 1 of 1
      • Lift the keyboard bezel from the back end and slide the iFixit opening tool around the perimeter of the bezel until it is fully released.
      Ask FixBot
    1. HP Mini 110-3131dx Touchpad Replacement, Touchpad: step 8, image 1 of 3 HP Mini 110-3131dx Touchpad Replacement, Touchpad: step 8, image 2 of 3 HP Mini 110-3131dx Touchpad Replacement, Touchpad: step 8, image 3 of 3
      • Turn the keyboard so that the touchpad is close to you.
      • Detach the ribbon cable from the connector on the touchpad circuit board using your fingernail or an opening tool.
      • Remove the four 2.9 mm screws from the bracket using a Phillips #0 screwdriver.
      • Remove the touchpad from the top of the keyboard bezel on the touch-sensitive side.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
2 other people completed this guide.
aarondcollege
1,318 Reputation
10 Guides authored
USF Tampa, Team 2-4, Cagle Fall 2016 Member of USF Tampa, Team 2-4, Cagle Fall 2016
USFT-CAGLE-F16S2G4
5 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 26
Past 30 Days: 104
All Time: 1,259
