HP Mini 110-3131dx Screen Replacement
      • Power off the laptop before trying to remove the battery.
      • Turn the laptop upside down, and locate the sliding tabs on the battery.
      • Slide both tabs in an inward direction, then slide the battery away from the laptop.
      Ask FixBot
    1. HP Mini 110-3131dx Screen Replacement, Screen: step 2, image 1 of 3 HP Mini 110-3131dx Screen Replacement, Screen: step 2, image 2 of 3 HP Mini 110-3131dx Screen Replacement, Screen: step 2, image 3 of 3
      • Slightly tilt the screen downward.
      • The screen is attached by internal clips and adhesive, which means that some force will be necessary for this step.
      • Use the plastic opening tool to force the screen bezel from the screen.
      • Locate the eight silver 2.9mm screws attaching the screen to the lid.
      • Using a PH1 philips head screwdriver detach the screws.
      Ask FixBot
aarondcollege
1,318 Reputation
10 Guides authored
USF Tampa, Team 2-4, Cagle Fall 2016 Member of USF Tampa, Team 2-4, Cagle Fall 2016
USFT-CAGLE-F16S2G4
5 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 112
All Time: 971
