HP Mini 110-3131dx Memory Card Replacement
      • Power off the laptop before trying to remove the battery.
      • Turn the laptop upside down, and locate the sliding tabs on the battery.
      • Slide both tabs in an inward direction, then slide the battery away from the laptop.
      Ask FixBot
    1. HP Mini 110-3131dx Memory Card Replacement, Back Cover: step 2, image 1 of 2 HP Mini 110-3131dx Memory Card Replacement, Back Cover: step 2, image 2 of 2
      • To remove the bottom cover pull the orange tab to the right until it clicks.
      • Carefully disconnect the clips as you lift the bottom cover.
      Ask FixBot
    1. HP Mini 110-3131dx Memory Card Replacement, Memory Card: step 3, image 1 of 3 HP Mini 110-3131dx Memory Card Replacement, Memory Card: step 3, image 2 of 3 HP Mini 110-3131dx Memory Card Replacement, Memory Card: step 3, image 3 of 3
      • Find the two silver screws that hold the memory card cover.
      • Take a PH1 screwdriver and unscrew the two screws.
      • Remove the metal cover
      Ask FixBot
    2. HP Mini 110-3131dx Memory Card Replacement: step 4, image 1 of 2 HP Mini 110-3131dx Memory Card Replacement: step 4, image 2 of 2
      • Pull the two white tabs located on either side of the memory card away from each other until the card pops up
      • Remove the card
      Ask FixBot
To install the new memory card, follow these instructions in reverse order.
aarondcollege
1,318 Reputation
10 Guides authored
USF Tampa, Team 2-4, Cagle Fall 2016 Member of USF Tampa, Team 2-4, Cagle Fall 2016
USFT-CAGLE-F16S2G4
5 Members
120 Guides authored
1 Guide Comment
what ram she using hp mini
ASKAR MALAYA - Reply Share
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 94
All Time: 1,167
