HP Mini 110-3131dx Keyboard Replacement
      • Power off the laptop before trying to remove the battery.
      • Turn the laptop upside down, and locate the sliding tabs on the battery.
      • Slide both tabs in an inward direction, then slide the battery away from the laptop.
      Ask FixBot
    1. HP Mini 110-3131dx Keyboard Replacement, Back Cover: step 2, image 1 of 2 HP Mini 110-3131dx Keyboard Replacement, Back Cover: step 2, image 2 of 2
      • To remove the bottom cover pull the orange tab to the right until it clicks.
      • Carefully disconnect the clips as you lift the bottom cover.
      Ask FixBot
    1. HP Mini 110-3131dx Keyboard Replacement, Keyboard: step 3, image 1 of 1
      • Remove the three black screws marked by the keyboard symbol using a Phillips #1 screwdriver.
      Ask FixBot
    2. HP Mini 110-3131dx Keyboard Replacement: step 4, image 1 of 3 HP Mini 110-3131dx Keyboard Replacement: step 4, image 2 of 3 HP Mini 110-3131dx Keyboard Replacement: step 4, image 3 of 3
      • Turn the laptop upright and open it.
      • Disconnect the clips located around the perimeter of the keyboard.
      • Slide the iFixit opening tool between the top edge of the keyboard and the plastic bezel.
      • Start either above the esc key or the delete key.
      • Pull the keyboard with your fingers until it comes out on both sides.
      • Be careful not to pull the keyboard out too fast. There is a fragile ribbon cable that attaches to the motherboard behind the keyboard.
      Ask FixBot
    3. HP Mini 110-3131dx Keyboard Replacement: step 5, image 1 of 1
      • Tilt the keyboard toward you to reveal the ribbon cable.
      • Lift up the black tab on top of the keyboard ribbon cable to release the ribbon cable.
      • Pull the ribbon cable out of its container.
      Ask FixBot
To install a different keyboard, follow these instructions in reverse order.
2 other people completed this guide.
aarondcollege
1,318 Reputation
10 Guides authored
USF Tampa, Team 2-4, Cagle Fall 2016 Member of USF Tampa, Team 2-4, Cagle Fall 2016
USFT-CAGLE-F16S2G4
5 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 96
All Time: 2,759
