HP Mini 110-3131dx Hard Drive Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
36
Past 30 Days:
109
All Time:
2,215
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 3 minutes
Difficulty: Easy
Needs More Images
A few more images would make this guide's procedures crystal clear.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
      • Power off the laptop before trying to remove the battery.
      • Turn the laptop upside down, and locate the sliding tabs on the battery.
      • Slide both tabs in an inward direction, then slide the battery away from the laptop.
      Ask FixBot
    1. HP Mini 110-3131dx Hard Drive Replacement, Back Cover: step 2, image 1 of 2 HP Mini 110-3131dx Hard Drive Replacement, Back Cover: step 2, image 2 of 2
      • To remove the bottom cover pull the orange tab to the right until it clicks.
      • Carefully disconnect the clips as you lift the bottom cover.
      Ask FixBot
    1. HP Mini 110-3131dx Hard Drive Replacement, Hard Drive: step 3, image 1 of 1
      • Remove the four screws holding down the hard drive using a Phillips #1 screwdriver.
      Ask FixBot
    2. HP Mini 110-3131dx Hard Drive Replacement: step 4, image 1 of 2 HP Mini 110-3131dx Hard Drive Replacement: step 4, image 2 of 2
      • Lift the black flap covering the hard drive then slide it towards the left using the orange tab until it's released from its receptacle.
      • Pull the hard drive out of the laptop.
      • Put the hard drive in an anti-static bag to decrease the likelihood of harming it with static electricity.
      Ask FixBot
To reinstall a new or old hard drive, follow these instructions in reverse order.
3 other people completed this guide.
aarondcollege
1,318 Reputation
10 Guides authored
USF Tampa, Team 2-4, Cagle Fall 2016 Member of USF Tampa, Team 2-4, Cagle Fall 2016
USFT-CAGLE-F16S2G4
5 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 36
Past 30 Days: 109
All Time: 2,215
