HP Mini 110-1046NR Memory Card Replacement
    1. HP Mini 110-1046NR Memory Card Replacement, Battery: step 1, image 1 of 3 HP Mini 110-1046NR Memory Card Replacement, Battery: step 1, image 2 of 3 HP Mini 110-1046NR Memory Card Replacement, Battery: step 1, image 3 of 3
      • Power-off the netbook fully before attempting to remove the battery.
      • Flip your netbook upside down, and locate the sliding tabs near the battery.
      • Slide both tabs inward so that the battery visibly moves away from the case of the computer.
      • Release the tabs and pull the battery out.
      Ask FixBot
    1. HP Mini 110-1046NR Memory Card Replacement, Memory Card Cover: step 2, image 1 of 3 HP Mini 110-1046NR Memory Card Replacement, Memory Card Cover: step 2, image 2 of 3 HP Mini 110-1046NR Memory Card Replacement, Memory Card Cover: step 2, image 3 of 3
      • Flip the netbook over so you are looking at the bottom, and locate the two screws that hold the memory card cover.
      • Next, take a Phillips PH1 screwdriver and unscrew the two screws.
      • These screws will not release from the cover once they are unscrewed.
      • If necessary, use the flat end of the spudger to assist in prying the cover away from the computer.
      Ask FixBot
    1. HP Mini 110-1046NR Memory Card Replacement, Memory Card: step 3, image 1 of 3 HP Mini 110-1046NR Memory Card Replacement, Memory Card: step 3, image 2 of 3 HP Mini 110-1046NR Memory Card Replacement, Memory Card: step 3, image 3 of 3
      • Carefully push the clips to the side, away from the memory card.
      • Note: The memory module is spring-loaded and will pop out when the clips are detatched.
      • Slide the memory card straight out, holding it as shown to avoid getting skin oils on the electrical contacts.
      Ask FixBot
2 other people completed this guide.
Jared Cooper
649 Reputation
5 Guides authored
Clemson, Team 14-1, Benson Fall 2013 Member of Clemson, Team 14-1, Benson Fall 2013
CLEM-BENSON-F13S14G1
3 Members
144 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 24
All Time: 1,699
