Up to 20% off select tools
HP Mini 1000 Upper Case Replacement
Views: 3.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
75
All Time:
3,184
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
Replace the upper case in your HP Mini 1000.
    1. HP Mini 1000 Upper Case Replacement, Battery: step 1, image 1 of 2 HP Mini 1000 Upper Case Replacement, Battery: step 1, image 2 of 2
      • With the case closed, place the Mini 1000 top-side down on a flat surface.
      • Push both of the battery release latches toward each other.
      Ask FixBot
    2. HP Mini 1000 Upper Case Replacement: step 2, image 1 of 1
      • Lift the battery out of the Mini 1000 from the edge closest to the release latches.
      Ask FixBot
    1. HP Mini 1000 Upper Case Replacement, Keyboard: step 3, image 1 of 1
      • Remove the following two screws:
      • One 6 mm Phillips screw
      • One 4 mm Phillips screw
      Ask FixBot
    2. HP Mini 1000 Upper Case Replacement: step 4, image 1 of 3 HP Mini 1000 Upper Case Replacement: step 4, image 2 of 3 HP Mini 1000 Upper Case Replacement: step 4, image 3 of 3
      • To facilitate the removal of the keyboard, it is recommended to push the keyboard outwards with one hand through the opening (highlighted in the third picture) located on the backside of the Mini 1000.
      • While pushing through the opening with one hand, grasp the left upper edge with the other hand and slightly pull the keyboard towards you.
      • Once an opening has been established, grasp the keyboard and slowly lift it upwards along the upper perimeter of the top edge.
      Ask FixBot
    3. HP Mini 1000 Upper Case Replacement: step 5, image 1 of 1
      • Lift the keyboard out of the upper case, minding the cable that is still connecting it to the motherboard.
      Ask FixBot
    4. HP Mini 1000 Upper Case Replacement: step 6, image 1 of 1
      • Use your fingernail or the flat end of a spudger to flip up the retaining flap on the keyboard cable ZIF socket.
      • Be sure you are prying up on the retaining flap, not the socket itself.
      • Pull the cable out of its socket and remove the keyboard.
      Ask FixBot
    1. HP Mini 1000 Upper Case Replacement, Hard Drive: step 7, image 1 of 2 HP Mini 1000 Upper Case Replacement, Hard Drive: step 7, image 2 of 2
      • Use your fingernail or the flat end of a spudger to flip up the retaining flap on the SIM card ribbon cable ZIF socket.
      • Pull the SIM card ribbon cable out of its socket and peel it off the top of the hard drive enclosure.
      Ask FixBot
    2. HP Mini 1000 Upper Case Replacement: step 8, image 1 of 1
      • Use your fingernail or the flat end of a spudger to flip up the retaining flap on the hard drive cable ZIF socket.
      Ask FixBot
    3. HP Mini 1000 Upper Case Replacement: step 9, image 1 of 1
      • Remove the two 4.5 mm Phillips screws securing the hard drive to the lower case.
      Ask FixBot
    4. HP Mini 1000 Upper Case Replacement: step 10, image 1 of 2 HP Mini 1000 Upper Case Replacement: step 10, image 2 of 2
      • Lift the hard drive up and out of the lower case, being careful not to damage its cable in the process.
      Ask FixBot
    1. HP Mini 1000 Upper Case Replacement, Upper Case: step 11, image 1 of 1
      • Using the sharp tip of a spudger, pry and remove the four plastic screw covers from the underside of the HP Mini 1000.
      • There are three different variations of the covers:
      • The two bottom covers are short in height and are notched to prevent incorrect insertion
      • The upper right cover is taller in height and is notched.
      • The upper left cover is taller in height and is not notched.
      Ask FixBot
    2. HP Mini 1000 Upper Case Replacement: step 12, image 1 of 1
      • Remove the four 7 mm Phillips screws that secure the upper case to the lower case.
      Ask FixBot
    3. HP Mini 1000 Upper Case Replacement: step 13, image 1 of 1
      • Flip the computer over and open the display.
      • Remove the two 4.5 mm Phillips screws securing the upper case to the lower case.
      Ask FixBot
    4. HP Mini 1000 Upper Case Replacement: step 14, image 1 of 2 HP Mini 1000 Upper Case Replacement: step 14, image 2 of 2
      • Wedge the flat end of a spudger in between the upper case and lower case near the bottom right corner of the display.
      • Carefully pry and rock the spudger upwards to create a small gap between the upper case and lower case.
      • Continue the previously described motion along the right edge of the upper case to release the clips securing the upper case to the lower case.
      Ask FixBot
    5. HP Mini 1000 Upper Case Replacement: step 15, image 1 of 2 HP Mini 1000 Upper Case Replacement: step 15, image 2 of 2
      • Repeat the same procedure as mentioned in the previous step to release the clips along the left side of the upper case.
      Ask FixBot
    6. HP Mini 1000 Upper Case Replacement: step 16, image 1 of 1
      • Grasp the upper case and carefully lift it slightly upwards, freeing it from any remaining clips.
      • The upper case is still attached via the TouchPad ribbon cable that is connected to the motherboard. Do not remove it completely just yet.
      Ask FixBot
    7. HP Mini 1000 Upper Case Replacement: step 17, image 1 of 1
      • Lay the upper case on top of the upper portion of the motherboard.
      • Use your fingernail or the flat end of a spudger to flip up the retaining flap on the TouchPad cable ZIF socket.
      • Pull the TouchPad ribbon cable out of its socket.
      • Remove the upper case from the HP Mini 1000.
      Ask FixBot
Author
with
Walter Galan
712,031 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 75
All Time: 3,184
